RouterOS v7.0beta1 (ARM)
From Russian MUM 2019. Currently available for downloading from http://mt.lv/v7.
please also share MIPSBE version
Awesome, installing it on a spare 3011. Is there a special version of winbox needed? Or any changelog available?
I can’t read that!
Will work with the winbox.exe You have. No special version needed.
  • 7.0beta1 available for testing.
  • For 5G-devices and other modems
  • More information on MikroTik.com
Have any special instructions been given?
I see a netinstall and an npk, do you need to use netinstall or is it enough to upload the npk and reboot?
Is it limited to certain ARM devices or can it be used on all of them? (I have an unused LHG ac that I could try it on)
No other instructions was given. Heard hAP ac² and some other devices mentioned, so I guess there’s no restrictions on 4G-5G devices only.
Currently running it on a RB3011 so I think it will be all arm devices.
Drag NPK into Files, double reboot, done. Works well on hAP AC2, no visible difference atleast now. Linux kernel has upgraded from 3.3.5 to 4.14.131.
Ok thanks, nice project for the weekend :slight_smile:
So instead of a kernel from 2012 we are now going to have a kernel from 2017.
Lets hope they can update this to the 4.19 version soon.
4.14 has longer EOL than 4.19
Good point!
Why stop at 4.19 … MT should go for 5.3 … ROS 7.0 is beta, and linux kernel 5.3 is RC. With current pace, linux kernel will be at least at 5.8 long term before ROS V7 hits stable…
Added ext4 support ?
For real stability you need to have long term support, and also use proven technology.
Maybe I am looking with my nose.. but is there a changelog available?
http://forum.mikrotik.com/t/queue-tree-mrtg-config-files/405/1
Currently v7 has v6.45.5 feature set. Main change is a new Linux Kernel, rest of features will gradually come out in next builds as for now we want to ensure that v7 is stable on hAP ac^2 and WAPGR LTE/4G/LTE-US boards mainly (and other boards) to get v7 ready for upcomming 5G products.
