Hi.
I have problems with my web proxy. When I download for second time any file less than max. cache size, so less than ~25MB, it downloads from internet again not from cache. Maybe the rule for caching all packets from proxy, DSCP=4 is not working properly,
23 ;;; HIT TRAFFIC FROM PROXY
chain=output action=mark-packet new-packet-mark=proxyhit passthrough=no out-interface=Local dscp=4
or web proxy cache does not work at all.
I am using 3.30 RouterOS version on Intel processor based PC
Please, may someone help me to clear this thing.
thank you.
My config is:
[admin@MikroTik] > ip proxy pr
enabled: yes
src-address: 0.0.0.0
port: 800
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-administrator: "webmaster"
max-cache-size: 25200KiB
cache-on-disk: yes
max-client-connections: 500
max-server-connections: 500
max-fresh-time: 4w2d
serialize-connections: yes
always-from-cache: yes
cache-hit-dscp: 4
cache-drive: sata1
[admin@MikroTik] > ip firewall filter print
0 chain=input action=accept protocol=tcp src-address=192.168.0.0/16 in-interface=Local dst-port=800
1 chain=input action=accept protocol=tcp in-interface=WAN1 dst-port=500
2 X chain=input action=drop dst-address-list=facebook in-interface=Local
3 X chain=input action=accept src-address=192.168.12.100 in-interface=Local
4 chain=forward action=drop protocol=udp dst-address=209.249.222.80 dst-port=53
5 ;;; drop all traffic brute force attack sources
chain=input action=drop src-address-list=sshblacklist
6 ;;; add new failed sshdarkgreylist to sshblacklist
chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=sshdarkgreylist address-list=sshblacklist
address-list-timeout=1h dst-port=21,22
7 ;;; add new failed sshgreylist to sshdarkgreylist
chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=sshgreylist address-list=sshdarkgreylist
address-list-timeout=1m dst-port=21,22
8 ;;; add new failed sshlightgreylist to sshgreylist
chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=sshlightgreylist address-list=sshgreylist
9 ;;; new connections to sshlightgreylist
chain=input action=add-src-to-address-list connection-state=new protocol=tcp address-list=sshlightgreylist address-list-timeout=1m dst-port=21,22
10 X chain=input action=drop protocol=tcp src-address=211.21.47.50 dst-port=21
11 ;;; Allow traffic between clients
chain=forward action=accept in-interface=Local out-interface=Local
12 chain=input action=accept src-address=xx.xx.xx..171 in-interface=!Local
13 chain=input action=drop protocol=tcp dst-port=21
14 X chain=input action=drop in-interface=!Local connection-type=ftp
15 X chain=forward action=drop
16 X chain=input action=drop
17 X chain=input action=drop src-address=60.217.229.220
18 X chain=forward action=drop dst-address=192.168.12.211
19 X chain=input action=drop layer7-protocol=(unknown)
20 ;;; Drop Telnet from Outside
chain=input action=drop protocol=tcp in-interface=!Local dst-port=23
21 ;;; WEB Proxy from outside
chain=input action=drop protocol=tcp src-address=0.0.0.0/0 in-interface=WAN1 dst-port=800
22 chain=input action=drop protocol=tcp src-address=0.0.0.0/0 in-interface=WAN2 dst-port=800
23 chain=input action=drop protocol=tcp src-address=0.0.0.0/0 in-interface=WAN3 dst-port=800
24 X chain=input action=accept src-address=192.168.12.0/24
25 X chain=input action=accept dst-address=192.168.12.0/24
26 chain=input action=accept src-address-list=Local-active-addresses
27 chain=input action=accept dst-address-list=Local-active-addresses
28 chain=forward action=accept src-address-list=Local-active-addresses
29 chain=forward action=accept dst-address-list=Local-active-addresses
30 chain=forward action=reject reject-with=icmp-network-unreachable protocol=tcp dst-port=25
31 ;;; To WEB proxy
chain=input action=reject reject-with=icmp-network-unreachable protocol=tcp src-address=!192.168.0.0/16 dst-port=800
32 chain=output action=reject reject-with=icmp-network-unreachable protocol=tcp dst-address=xx.xx.xx.247 dst-port=800
33 chain=output action=reject reject-with=icmp-network-unreachable protocol=tcp dst-address=73.106.3.43 dst-port=800
34 chain=output action=reject reject-with=icmp-network-unreachable protocol=tcp dst-address=xx.xx.xx..207 dst-port=800
35 X chain=input action=reject reject-with=icmp-network-unreachable protocol=tcp dst-port=445
36 chain=input action=drop src-address=192.168.12.124
37 chain=input action=drop dst-address=192.168.12.124
38 X ;;; P2P
chain=forward action=drop p2p=bit-torrent
39 X chain=forward action=drop p2p=blubster
40 X chain=forward action=drop p2p=direct-connect
41 X chain=forward action=drop p2p=edonkey
42 X chain=forward action=drop p2p=fasttrack
43 X chain=forward action=drop p2p=gnutella
44 X chain=forward action=drop p2p=soulseek
45 X chain=forward action=drop p2p=warez
46 X chain=forward action=drop p2p=winmx
47 X chain=forward action=drop protocol=tcp src-port=3074
48 X chain=forward action=drop protocol=udp src-port=3074
49 X chain=forward action=drop src-address=192.168.0.0/16
50 X chain=forward action=drop dst-address=192.168.0.0/16
51 ;;; All Local Network Block
chain=input action=drop src-address=192.168.0.0/16
52 chain=input action=drop dst-address=192.168.0.0/16
53 I ;;; Check if dest is an open customer
chain=forward action=jump jump-target=open-customers dst-address-list=open-customers
54 I ;;; Check Known Bad Hosts
chain=forward action=jump jump-target=bad-hosts
55 ;;; Reject if in the 24-hour-list
chain=forward action=reject reject-with=icmp-network-unreachable src-address-list=24-hour-list
56 ;;; Take no action on bogons
chain=bad-host-detection action=return src-address-list=bogons
57 ;;; Add to the 30 second list
chain=bad-host-detection action=add-src-to-address-list address-list=30-seond-list address-list-timeout=30s
58 chain=bad-host-detection action=return
59 ;;; jump to the bad-host-detection chain
chain=forward action=jump jump-target=bad-host-detection src-address-list=!local-addr
60 ;;; jump to the bad-host-detection chain
61 X ;;; log and reject the rest
chain=forward action=log log-prefix=""
62 chain=forward action=reject reject-with=icmp-network-unreachable
[admin@MikroTik] > ip firewall mangle pr
0 X chain=postrouting action=mark-connection new-connection-mark=DNS_conn passthrough=yes protocol=udp out-interface=!Local dst-port=53
1 X chain=prerouting action=mark-routing new-routing-mark=DNS_rou passthrough=yes connection-mark=DNS_conn
2 X chain=input action=accept src-address=192.168.11.100 in-interface=Local connection-bytes=0-500000
3 chain=input action=mark-connection new-connection-mark=pub1_conn passthrough=yes in-interface=WAN1
4 chain=input action=mark-connection new-connection-mark=pub2_conn passthrough=yes in-interface=WAN2
5 chain=input action=mark-connection new-connection-mark=pub3_conn passthrough=yes in-interface=WAN3
6 chain=output action=mark-routing new-routing-mark=to_pub1 passthrough=yes connection-mark=pub1_conn
7 chain=output action=mark-routing new-routing-mark=to_pub2 passthrough=yes connection-mark=pub2_conn
8 chain=output action=mark-routing new-routing-mark=to_pub3 passthrough=yes connection-mark=pub3_conn
9 chain=prerouting action=accept dst-address=80.78.75.0/24 in-interface=Local
10 chain=prerouting action=accept dst-address=79.106.3.0/24 in-interface=Local
11 chain=prerouting action=mark-connection new-connection-mark=pub1_conn passthrough=yes dst-address-type=!local in-interface=Local
per-connection-classifier=both-addresses:3/0
12 chain=prerouting action=mark-connection new-connection-mark=pub2_conn passthrough=yes dst-address-type=!local in-interface=Local
per-connection-classifier=both-addresses:3/1
13 chain=prerouting action=mark-connection new-connection-mark=pub3_conn passthrough=yes dst-address-type=!local in-interface=Local
per-connection-classifier=both-addresses:3/2
14 chain=prerouting action=mark-routing new-routing-mark=to_pub1 passthrough=yes in-interface=Local connection-mark=pub1_conn
15 chain=prerouting action=mark-routing new-routing-mark=to_pub2 passthrough=yes in-interface=Local connection-mark=pub3_conn
16 chain=prerouting action=mark-routing new-routing-mark=to_pub3 passthrough=yes in-interface=Local connection-mark=pub2_conn
17 ;;; facebook upload
chain=prerouting action=mark-routing new-routing-mark=facebook passthrough=yes dst-address-list=facebook in-interface=Local
18 ;;; mark http connections
chain=prerouting action=mark-connection new-connection-mark=http passthrough=yes protocol=tcp in-interface=Local dst-port=80
19 ;;; Route mark messenger TCP ports
chain=prerouting action=mark-routing new-routing-mark=messengers_routeup passthrough=yes protocol=tcp in-interface=Local
dst-port=1503,1863,5000,5001,5050,5100,5190-6901,54055
20 ;;; Route mark messenger UDP ports
chain=prerouting action=mark-connection new-connection-mark=messengers_routeup passthrough=yes protocol=udp in-interface=Local
dst-port=1503,5000-5010,5109,6901,54055
21 ;;; Route mark Skype
chain=prerouting action=mark-routing new-routing-mark=messengers_routeup passthrough=yes layer7-protocol=skypeout in-interface=Local
22 chain=prerouting action=mark-routing new-routing-mark=messengers_routeup passthrough=yes layer7-protocol=skypetoskype in-interface=Local
[admin@MikroTik] /ip firewall nat> pr
0 chain=srcnat action=masquerade out-interface=WAN1
1 chain=srcnat action=masquerade out-interface=WAN2
2 chain=srcnat action=masquerade out-interface=WAN3
3 chain=dstnat action=dst-nat to-addresses=192.168.12.100 to-ports=3389 protocol=tcp dst-address=xx.xx.xx.247 dst-port=3389
4 chain=dstnat action=dst-nat to-addresses=192.168.12.20 to-ports=8080 protocol=tcp dst-address=xx.xx.xx.247 dst-port=8080
5 chain=dstnat action=dst-nat to-addresses=192.168.12.21 to-ports=8081 protocol=tcp dst-address=xx.xx.xx.247 dst-port=8081
6 ;;; Transparent DNS Cache
chain=dstnat action=redirect in-interface=Local connection-mark=dns
7 ;;; Transparent Web Cache
chain=dstnat action=redirect to-ports=800 protocol=tcp in-interface=Local connection-mark=http
8 ;;; Transparent proxy for NTP requests
chain=dstnat action=redirect in-interface=Local connection-mark=ntp
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 xx.xx.xx.225 1
1 A S 0.0.0.0/0 xx.xx.xx.1%WAN2 1
2 A S 0.0.0.0/0 xx.xx.xx.1%WAN3 1
3 A S 0.0.0.0/0 WAN1 1
4 S 0.0.0.0/0 WAN3 2
WAN2
5 A S 0.0.0.0/0 Local 1
6 X S 0.0.0.0/0 WAN1 1
7 A S 0.0.0.0/0 Local 1
8 A S 0.0.0.0/0 WAN3 1
9 DS 0.0.0.0/0 xx.xx.xx.1 1
10 DS 0.0.0.0/0 xx.xx.xx.1 1
11 S 0.0.0.0/0 xx.xx.xx.225 2
12 S 0.0.0.0/0 WAN2 3
13 ADC xx.xx.xx.1/32 xx.xx.xx.207 WAN3 0
WAN2
14 ADC xx.xx.xx.224/27 xx.xx.xx.247 WAN1 0
15 ADC 192.168.0.0/16 192.168.0.0 Local 0
16 A S 192.168.11.0/24 Local 1
17 ADC 192.168.11.0/32 192.168.11.1 Local 0
18 ADC 192.168.12.0/24 192.168.12.1 Local 0
