Hi there,
I got a lot of problems with new hardware to install RouterOS 5.12v, I created a ticket at support, but the problem is not resolved.
I listed my hardware in the wiki supported hardware
ASUS P8H67-V (Intel® H67(B3), 3xPCI, 4xPCI-E) 5.XX
Don’t work. “Kernel Panic”. Mikrotik has not driver compatibility with this motherboard.
I will try to change my HW with the provider, but I need a supported hardware list with 5.12v to know what should I buy.
Can anyone provide me any list of compatible HW with this version? I did the same question through support@mikrotik.com but I didn’t get any response about this yet.
I need compatibility with one motherboard that support 5 PCI or PCIe ethernet boards, Intel i5 and Sata drive.
I will appreciate any information.
Thank you
Fabian
Thank you.
