Hello, I have spend few days in thinking about how this can be done. I have two rooms in my house with two routers connected to ISP 1 and ISP2, and two local networks.
Room1 has CRS125-24G-1S which is connected directly to WAN ISP1 and local dhcp network 192.168.81.0/24. On this network i have few devices connected pc, synology etc.
Room2 has RB2011UiAS-2HnD which is connected to another WAN ISP2 and local network dhcp network 192.168.82.0/24 , on this network also I have another machines connected laptop, satbox etc.
Both routers are connected on ether3 directly with 7 meters UTP cable. I want all local traffic to be routed between these two ether points.
The problem is that I can’t ping or reach the devices from room1 to room2 and vice versa.
example:
I want to access to my synology from room 2 with network 192.168.82.0/24
Synology is on network 192.168.81.0/24
Here is the topology on my network
setup config from room1 CRS125-24G-1S
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="DHCP Server"
set [ find default-name=ether3 ] comment="Local to RB2011UiAS-2HnD"
add name=dhcp_pool0 ranges=192.168.81.2-192.168.81.254
add address-pool=dhcp_pool0 disabled=no interface=ether2 name=dhcp1
add address=192.168.81.1/24 interface=ether2 network=192.168.81.0
add address=5.5.5.1/24 interface=ether3 network=5.5.5.0
/ip dhcp-client
add disabled=no interface=ether1
add address=5.5.5.0/24 gateway=5.5.5.2
add address=192.168.81.0/24 gateway=192.168.81.1
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.81.0/24
/system identity
set name=CRS125-24G-1S
setup config room2 RB2011UiAS-2HnD
set [ find default-name=ether2 ] comment=DHCP-Server
set [ find default-name=ether3 ] comment="Local to CRS125-24G-1S"
add name=dhcp_pool0 ranges=192.168.82.2-192.168.82.254
add address=192.168.82.1/24 interface=ether2 network=192.168.82.0
add address=5.5.5.2/24 interface=ether3 network=5.5.5.0
/ip dhcp-client
add address=5.5.5.0/24 gateway=5.5.5.1
add address=192.168.82.0/24 gateway=192.168.82.1
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.82.0/24
/system identity
set name=RB2011UiAS-2HnD
