Hi everybody,
First I'm sorry for there are so much topic of PPC Load Balancing, I have searched some topics but It doesn't solve my own problem.
I'm setting a network with 2 WAN using PPPOE, It worked well until I create new Vlans (First I just had one LAN). The problem is that I can't access through Vlans after PPC Load Balancing. Below is my script, is there anyone here who has had the same problems?.
I would appreciate hearing your opinion on this case.
jul/18/2018 15:24:01 by RouterOS 6.42.4
software id = 5RKA-6A72
model = CRS326-24G-2S+
serial number = 763C07B33D5A
add fast-forward=no name=LAN
add fast-forward=no name=Trunk vlan-filtering=yes
/interface pppoe-client
add disabled=no interface=ether1 name=pppoe-out1 user=user1
add disabled=no interface=ether2 name=pppoe-out2 user=user2
/interface vlan
add interface=Trunk name=vlan10 vlan-id=10
add interface=Trunk name=vlan20 vlan-id=20
add interface=Trunk name=vlan30 vlan-id=30
add interface=Trunk name=vlan40 vlan-id=40
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
add name=dhcp_pool2 ranges=10.10.30.2-10.10.30.254
add name=dhcp_pool3 ranges=10.10.20.2-10.10.20.254
add name=dhcp_pool4 ranges=10.10.40.2-10.10.40.254
add address-pool=dhcp_pool0 disabled=no interface=LAN name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=vlan10 name=dhcp2
add address-pool=dhcp_pool2 disabled=no interface=vlan30 name=dhcp3
add address-pool=dhcp_pool3 disabled=no interface=vlan20 name=dhcp4
add address-pool=dhcp_pool4 disabled=no interface=vlan40 name=dhcp5
add bridge=LAN interface=ether3
add bridge=Trunk interface=ether4 pvid=10
add bridge=Trunk interface=ether6 pvid=20
add bridge=Trunk interface=ether8 pvid=30
add bridge=Trunk interface=ether10 pvid=40
/interface bridge vlan
add bridge=Trunk tagged=ether6,ether8,ether10,Trunk untagged=ether4 vlan-ids=10
add bridge=Trunk tagged=ether4,ether8,ether10,Trunk untagged=ether6 vlan-ids=20
add bridge=Trunk tagged=ether4,ether6,ether10,Trunk untagged=ether8 vlan-ids=30
add bridge=Trunk tagged=ether4,ether6,ether8,Trunk untagged=ether10 vlan-ids=40
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
add address=10.10.10.1/24 interface=vlan10 network=10.10.10.0
add address=10.10.20.1/24 interface=vlan20 network=10.10.20.0
add address=10.10.30.1/24 interface=vlan30 network=10.10.30.0
add address=10.10.40.1/24 interface=vlan40 network=10.10.40.0
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.30.0/24 gateway=10.10.30.1
add address=10.10.40.0/24 gateway=10.10.40.1
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8
/ip firewall mangle
add action=mark-connection chain=input in-interface=pppoe-out1
new-connection-mark=WAN1_conn passthrough=yes
add action=mark-connection chain=input in-interface=pppoe-out2
new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn
new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn
new-routing-mark=to_WAN2 passthrough=yes
add action=mark-connection chain=prerouting dst-address-type=!local
in-interface=LAN new-connection-mark=WAN1_conn passthrough=yes
per-connection-classifier=both-addresses:2/0
in-interface=LAN new-connection-mark=WAN2_conn passthrough=yes
per-connection-classifier=both-addresses:2/1
in-interface=vlan10 new-connection-mark=WAN1_conn passthrough=yes
in-interface=vlan10 new-connection-mark=WAN2_conn passthrough=yes
in-interface=vlan20 new-connection-mark=WAN1_conn passthrough=yes
in-interface=vlan20 new-connection-mark=WAN2_conn passthrough=yes
in-interface=vlan30 new-connection-mark=WAN1_conn passthrough=yes
in-interface=vlan30 new-connection-mark=WAN2_conn passthrough=yes
in-interface=vlan40 new-connection-mark=WAN1_conn passthrough=yes
in-interface=vlan40 new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN1_conn
in-interface=LAN new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn
in-interface=LAN new-routing-mark=to_WAN2 passthrough=yes
in-interface=vlan10 new-routing-mark=to_WAN1 passthrough=yes
in-interface=vlan10 new-routing-mark=to_WAN2 passthrough=yes
in-interface=vlan20 new-routing-mark=to_WAN1 passthrough=yes
in-interface=vlan20 new-routing-mark=to_WAN2 passthrough=yes
in-interface=vlan30 new-routing-mark=to_WAN1 passthrough=yes
in-interface=vlan30 new-routing-mark=to_WAN2 passthrough=yes
in-interface=vlan40 new-routing-mark=to_WAN1 passthrough=yes
in-interface=vlan40 new-routing-mark=to_WAN2 passthrough=yes
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=pppoe-out2
add check-gateway=ping distance=1 gateway=pppoe-out1 routing-mark=t
add check-gateway=ping distance=1 gateway=pppoe-out2 routing-mark=t
add check-gateway=ping distance=2 gateway=pppoe-out2
