Hello. Have question that I cannot solve by myself so I’m looking for help. My all local network at home “sits” in 192.168.1.0/24. I have hikvision NVR with 8 POE ports. NVR’s IP is 192.168.1.169. When I check my connected cameras in NVR setting all of them gets IP with different subnet: 192.168.254.0/24. On my mikrotiks Route List I added route to 192.168.254.0/24 but I still cannot ping or connect to camera directly from browser. What am I missing?
https://m.youtube.com/watch?v=dqPIpFB7zkc
If you want to change camera IPs to ones from router subnet
Great ref video… indeed, nice camera setup and yes, thats what a friend of mine does, resets the camera Ip to be on the subnet he wants it to be.
Alternatively, you could add another subnet on your router just for NVR stuff and make it the default subnet the cameras are default given at the factory.
Depends if you want to get into multiple subnets and vlans at your location.
Personally I would do that anyway putting the cameras and NVR on their own subnet, without any internet access for the cameras, just the NVR IP itself. In this way
you can get alerts from the cameras at any time on your phone, local or remote.
Also, the nvr system would not have any direct access to any of my home devices/pcs by using vlans and separate subnet.
