I have four routers running BGP:
Cisco → 2. MT 2.9.30 → 3. MT 2.9.30 → 4. MT 2.9.29
Router 2 gets full routes from router 1. Router 3 gets full routes from router 4. However, router 2 and router 3 do not get full routes from each other.
How can I force the sending of full routes to these peers?
Beccara
September 17, 2006, 4:57am
2
Need more details?
Can you print bgp instance and peer config for all routers. Are you using iBgp or eBgp?
Here is the config for router #3 . I’m not able to get 66.XX.XX.0/24 to be advertised either.
/ routing bgp instance
set default name=“default” as=22361 router-id=63.XX.XX.1
redistribute-static=yes redistribute-connected=yes redistribute-rip=no
redistribute-ospf=no redistribute-other-bgp=yes out-filter=“”
client-to-client-reflection=yes comment=“” disabled=no
/ routing bgp peer
add name=“Cisco” instance=default remote-address=65.XX.XX.1 remote-as=22361
nexthop-choice=default multihop=yes route-reflect=no
hold-time=3m ttl=60 in-filter=mci_out out-filter=bgp_advertise comment=“”
disabled=no
add name=“Router #4 ” instance=default remote-address=63.XX.XX.221
remote-as=22361 nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=60 in-filter=level3_out out-filter=“”
add name=“Router #2 ” instance=default remote-address=65.XX.89
route-reflect=no hold-time=3m ttl=60 in-filter=mci_out out-filter=“”
/ routing filter
add chain=bgp_advertise prefix=63.XX.XX.0/24 prefix-length=24 invert-match=no
action=accept comment=“” disabled=no
add chain=bgp_advertise invert-match=no action=discard comment=“” disabled=no
add chain=level3_out prefix=65.XX.XX.0/23 prefix-length=23 invert-match=no
action=reject comment=“” disabled=no
add chain=level3_out protocol=bgp invert-match=no action=accept
set-nexthop=63.XX.XX.221 set-bgp-local-pref=50 comment=“” disabled=no
add chain=mci_out prefix=65.XX.XX.0/23 prefix-length=23 invert-match=no
add chain=mci_out protocol=bgp invert-match=no action=accept
set-nexthop=65.XX.XX.89 comment=“” disabled=no
add chain=level3_advertise prefix=65.XX.XX.0/24 prefix-length=24 protocol=bgp
invert-match=no action=accept comment=“” disabled=no
add chain=level3_advertise prefix=63.XX.XX.0/24 prefix-length=24 protocol=bgp
add chain=level3_advertise invert-match=no action=discard comment=“”
disabled=no
/ routing bgp network
add network=63.88.42.0/24 disabled=no
karyal
September 22, 2006, 7:14pm
4
believewireless:
Did you check why the routes are not propagated (probably discarded?)
Enable bgp logging.
Did you set “force self” option on “neighbour” under peers config?
Bye,
Ricky
What does the “force self” option do?
karyal
September 23, 2006, 7:41am
6
Forces ip address of the announcing router as nexthop for the announced routes to the corresponding peer.
The peer will discard the received routes if routes nexthop is thought as unreacheable.
forcing nexthop to the point to point ip of the peer makes the nexthop reacheable and the routes are not discarded anymore.
the option is available from 2.9.28 only though (and don’t use 2.9.28 as it has memory leak on the routing test packages).
Also, you should use routing-test package instead of routing package.
Bye,
Ricky
