Routing-Test Freezing System
Hi guys,
I am upgrading to 2.9.49 and on a couple of routers, after installing the new package the converting to routing-test, everything worked fine. However, on the majority of them, as soon as I enable routing-test and reboot, when the router boots back up I cannot see any of my interfaces, IP address, etc. I then disable routing-test, re-enable routing, and tell it to reboot. After it finally reboots (which takes forever) it comes back clean with the routing package working. I have tried uninstalling the routing-test package and re-installing just that package and that did not work either. Has anyone seen this problem before. Thanks.
Keith
