Routing-Test
new routing test, which supposedly fixes some BGP issues:
http://www.mikrotik.com/download/routing-test-2.9.25_new.zip
Good work guys, unfortunatelly the problem with the bgp session crashes still exists.
Apart from the problem with the bgp routes removal in 2.9.24, the problem with the crashes has arrived with the 2.9.25.
So i guess it has something to do with the latest changes you have made.
I have sent the supout.
When can we expect to see this in routeros-x86 package? some of us use the single file upgrade path
Please whoever uses this please post back with your experience
With standart routing-test on 2.9.25 have problem with
hold time expire. If i stay to only one ISP - no problems.
If i stay with two ISP`s - bgp sessions go somwhere faaaaar away .. :slight_smile:
and reseting again and again …sounds like my “dream” is to stay without internet connections :slight_smile:
Thanks again for NEW STABLE 2.9 :slight_smile: with suggested routing-test :slight_smile:
Im still wait for other problems :slight_smile: Another one night i cant sleep with mikrotik in trouble …
Thank you guys !! May be next time you want from me to paid for this “boogie nights” :slight_smile:
You mean the new routing-test is very good ?
appears so, when mentioning problems, he says standard test.
normis can you shed some light on [Ticket#2006060516000369] . I dont know what to do now. Its definately not my machines or the nics something internal to MT . What to do ?the interfaces stop working
I just sent you an email
got it. replied back could you reply back ?
Interesting way to do e-mail communicaton :smiley:
SCNR
Christian Meis
How else can i notify them ?
No offense intended. I myself did something similar using the chat room several times :wink:
Christian Meis
how else? email itself is a notification, isn’t it? i read email more often than forum
I did reply back with my problem but no response to that ticket yet .
you have to understant that we have a queuing mechanism, plus we are people too. problem solving is not as fast as writing emails. we will write as soon as we have an answer
I totally appreciate your hardwork, I just switched back to routing test on a secondary machine identical . I dont see any real advantage its still 100% cpu , im have 2 peers sending me 180k routes each. routing-test is slow.
did you use routing-test from this topic? we updated it you know …
i use package from topic - for last 12 hours everything is OK!!!
4 BGP sessions work great for now.
Thanks from me for fix and for “network” command too.
nikhill for testing purposes i have another one router with different hardware (intel motherboard, with intel network adapters, intel cpu
  • that i call “Trinity” :slight_smile: )
What kind of hardware use for your routers ?
I have working router with 2.9.25 and new routing-test from topic only.
And this variant works for me.
Thing twice and then go ahead again… last routing-test must works.
I checked nikhil’s supout.rif and he is using the standard routing package, not test
