I recently started reading regarding networking so I am new to this and also new to RouterOS. Previously I did some minor configuration in a OpenWRT router, but only through GUI.
In general what I am trying to do, is to use a Mikrotik router to “connect” two different networks. Below is my topology
Some notes
- For all cameras in Network B, the server (192.168.88.1) is currently configured as gateway
- Main router (192.168.68.1) is the DHCP Server for Network A
- Network B uses static IPs
My end target is
- Access any device in Network B from Network A
- Devices in Network B, to be able to access the internet
- Access Mikrotik router configuration interface (winbox) from Network A devices
What I did until now
- Set wlan1 interface to “station pseudobridge” and connect Mikrotik to Network A wirelessly as a client
- Set both wlan1 and ether1 as LAN
- Removed bridges
- Removed firewall rules
The problem is that:
- I can only access Mikrotik router configuration interface (winbox) from Laptop 2 (Network B). It can be accessed from devices in Network A
- Laptop 2 (Network B), and any device in Network B, does not have access to the internet
Below my routing configuration
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 S 0.0.0.0/0 192.168.68.1 1
1 S 192.168.68.0/24 192.168.68.1 1
2 DC 192.168.68.0/24 192.168.68.0 wlan1 255
3 ADC 192.168.88.0/24 192.168.88.0 ether1 0
4 S 192.168.88.0/24 192.168.88.251 1
As I understand I need to set some static routes in Mikrotik, but whatever I tried until now it didn’t work. Any ideas? Any tutorial that addresses my issue that I should read?
