Hi, I have a RB532 and made 2 ppp-oe connections on it , and defined 2 different networks with obviosly different dhcp-servers, now whatt I would like to do is route the traffic from one network on the one ppp-oe connection and the traffic from the other network to the other ppp-oe connection. I dont know if it is possible if so can somoene pls help me in doing so…
Q: you have made two PPPoE SERVER one is on wlan1 second on wlan2 OR you connected your RB on two other network via PPPoE CLIENT …
A1:if you are a SERVER then all your client must have YOU as GW and the routing is ok ..
A2:if you are a CLIENT on two separate NETWORK then network A must set route do network B via your IP on network A and network B must set route to netvork A via you IP on network B …
