RTS CTS
I am using V3.30 and I cannot find the settings to enable/disable RTS CTS
According to this wiki: http://wiki.mikrotik.com/wiki/Wireless#Frame_protection_support_.28RTS.2FCTS.29, I should be able to enable it with this command:
[admin@MikroTik] /interface wireless> set 0 hw-protection-mode=rts-cts hw-protection-threshold=0
But “hw-protection-mode” doesn’t appear as a configurable setting…Any ideas?
install the wireless-test package.
thanks, do I need to install it on AP and CPE? or just the CPE?
I’d suggest you to install it on both.. you will be amazed of it :smiley:
edit: You need on client side to enable rts cts, and if you install it on AP and you are using nstreme, you will get an HUGE improvement
wow really? Should have tried ages ago then haha…Will give it a shot 2nyt
thanks
Why do we need to install this separately?
Appreciated if you can share it…
wireless-test package replaces regular wireless package. Or if you upgrade to v4.x then you don’t need anything as the wireless-test=wireless in v4.x
oic…
just another question, can we running Nstreme_Dual in the V4.x with R52N??
