RTSP ALG
Is it possible to implement RTSP ALG with RouterOS ?
any updates on this. I also requested this some time ago but no reply. RTSP will be used by many VOD providers.
Mikrotik any updates on RTSP ALG support, sort of need this to make Cisco VoiP SCCP enabled end points to work behind a RB with NAT.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_zbf/configuration/xe-3s/sec-data-zbf-xe-book/sec-data-sccp.pdf
Hi
I second this, this is the only thing missing for setting up IPTV in our network.
I see that IGMP snooping support is being added in 6.41, that also was one of the missing pieces.
Best Regards
Haavard
+1
It’s strange that it has not been implemented yet!
Many problems with CCTV due to the lack of this feature.
Maybe there is some kind of information at least about the plans?
+1
RTSP ALG for multiple video streams thru mikrotik is sorely needed
Any news about this feature? Is it in the Mikrotik’s roadmap?
Kind regards.
+1 for RTSP2 2.0 (RFC 7826) ALG and/or proxy server in ROS.
+1
Weird that there is no RTSP ALG option in ROS. Even the most inexpensive routers support this.
+1
+1
Please provide RTSP ALG
+1
+1
Please, provide RTSP ALG
+1
6 years later and still nothing…
+1.
+1
Should be possible in ros7?
http://forum.mikrotik.com/t/rtsp-helper/146549/1
