Run different PPPoE clients on the same eth port with different mac address
I have 8 PPPoE accounts, all from the same ISP, I want to add these PPPoE clients and let them run on the same interface, unfortunately the PPPoE server doesn’t like multiple PPPoE connection with the same mac address, a workaround is to make a bridge over the interface and then i can change the mac address of the bridge and set the PPPoE client interface to the bridge, unfortunately it is not possible to add multiple bridges on a single interface so we’re back to square on.
Another workaround that i tried is connect a cable between two interfaces and run VLANS on between these interface, then bridge everything to the ISP interface, i tried it now i can connect as many clients as i like, but the solution is not clean and i get warning about a possible loop.
An ideal solution would be to run 8 cables to a switch and the switch is connected to the ISP cable, it would definitely work without a problem and every client will have it’s own mac, but i’m trying to keep the solution to one router, and also not waste 8 interfaces if possible.
any other solutions/ideas/workarounds ?
Regards
It’s not exactly clean either, but it looks like VRRP can be misused not only for multiple DHCP clients, but also for multiple PPPoE clients:
/interface vrrp
add interface=wan name=vrrp10 v3-protocol=ipv6 vrid=10
add interface=wan name=vrrp11 v3-protocol=ipv6 vrid=11
add interface=wan name=vrrp12 v3-protocol=ipv6 vrid=12
/interface pppoe-client
add interface=vrrp10 name=pppoe-out10
add interface=vrrp11 name=pppoe-out11
add interface=vrrp12 name=pppoe-out12
Server then sees VRRP MAC addresses 00:00:5E:00:02:0A, 00:00:5E:00:02:0B, 00:00:5E:00:02:0C, …
I’ve been using this trick for some time now it works perfectly, but recently I’ve been getting an “invalid” flag when adding an ipv6 VRRP interface, sometimes it works after rebooting the device, but now it always stays invalid, why is that?
I can’t say. Does it happen even when you just add it, before you do anything else with it? I don’t know what could cause that. Perhaps disabled IPv6 (I can’t test it right now)?
