running winbox via ubuntu 20.04
hello everyone
actually im installing winbox package on my ubuntu desktop but everything i click the icon, but nothing happens. and after that i cleat it out
what should i do for using winbox on my linux, im using it in exe mode via wine , but i prefer linux packages
thanks
best regards
mosi
mo.shabraf@gmail.com
Not sure what means ‘installing winbox package’ in ubuntu … It should work just fine if you install wine package. Then you can simply download winbox.exe from MT’s download server. Open terminal window in your ubuntu machine, navigate to the folder where you stored downloaded winbox executable and run
wine winbox.exe
If winbox doesn’t run, you should get some errors and warnings in the terminal window which should give some clue as to why winbox doesn’t run.
thanks for your reply
what i mean by installing winbox on my ubuntu is .deb package
but after surfing i find this too
wine winbox.exe
best regards
