I’ve just setup my new grovea 52 ac and hap ac in my RV.
I want to be able to connect to rv park wireless at rv parks when I arrive.
I have set port 5 as wan and added port 1 to bridge on the hap ac.
Connected GrooveA 52 AC to port 5 poe out of Hap ac
Rebooted Hap ac
The Groove is setup in CPE router mode with default settings and works when attached to my laptop. I can connect to rv park wireless.
The problem is when I connect the groove to the hap ac. They can not see each other. In the box that shows other routers nothing shows up.
The hap is set up as dual home ap in router mode. I have read all posts from boaters wanting to do the same thing and they did not work for me. I probably did not follow them correctly. I am completely new to routers and routing. I Think that because both devices are on different subnets I need to setup ip routes and nat rules but I do not know how to do that. Could someone please review my configuration give suggestions if needed.
All help will be appreciated.
GrooveA 52 AC
# aug/13/2020 16:53:38 by RouterOS 6.47.1
# software id = X03D-UPPV
# model = RBGrooveGA-52HPacn
# serial number = A7D70B8A0BAC
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed name=profile1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX \
disabled=no frequency=auto mode=station-pseudobridge security-profile=\
profile1 ssid=TengoInternet wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=wlan1 list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=wlan1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add distance=1 dst-address=192.168.89.0/24 gateway=192.168.89.1
/system clock
set time-zone-name=America/Boise
/system identity
set name=Imgrut
/tool mac-server
/tool mac-server mac-winbox
Hap AC
# aug/13/2020 18:29:16 by RouterOS 6.47.1
# software id = HQAL-CWFR
# model = RB962UiGS-5HacT2HnT
# serial number = C5610C4F6474
add admin-mac=48:8F:5A:05:F5:1F auto-mac=no comment=defconf name=bridge
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=profile1 \
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=auto mode=ap-bridge \
security-profile=profile1 ssid=StarLord2G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge security-profile=profile1 ssid=\
StarLord5G wireless-protocol=802.11
add name=dhcp ranges=192.168.89.10-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add interface=ether5 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
add address=192.168.89.1/24 comment=defconf interface=ether2 network=\
192.168.89.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether5
# DHCP client can not run on slave interface!
add disabled=no interface=ether1
add address=192.168.89.0/24 gateway=192.168.89.1 netmask=24
/ip dns static
add address=192.168.89.1 comment=defconf name=router.lan type=A
invalid
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.88.1
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=StarLord
/tool mac-server
