S.O.S. disconnected, control frame timeout
HELP PLEASE …
I have updated to the latest stable version (6.43.:sunglasses: my sxt lite ac5 and my ap, and now they are continuously disconnecting “disconnected, control frame timeout”
Has this happened to you and solved it?
Under Security Profiles, set your Group Key Update to: 01:00:00.
I currently use RADIO but attached security profile capture
Why 01:00:00?
Just a test to see if that was the issue. There was a bug in which it would change too rapidly and thus clients had issues.
Hi, I think I solved it in the following way:
When I upgraded to the latest version Mikrotik blocked the use of superchanel in Spain, that caused me that all the APs that had configured the country as Spain and superchanel, would emit only a frequency of 5Ghz that had a lot of noise
I hope you serve this resolution
