Same Subnets on adjacent routers getting: Ospf error "Discarding packet: Locally originated"
I want to be able to reach my clients CPE.
This is my setup: and I’m getting the error mentioned
The small circles represent pppoe-clients IP
Run OSPF only on one subet connecting both routers. Check whether RouterIDs are unique.
If I run the subnet on one router only it does not propagate the clients on the router that the subnet is not running on.
Advertise other subnets as external.
Please let me know how to do this
Hello. I have the same problem. Appears after about 56 active interfaces in one area, with any change in the status of ospf.
Apparently this is a bug routerOS
Correct. I had this issue and solved it this way.
So, two routers connecting to each other had the range 10.2.0.0/22 area=external added.
On one router i changed the area to area14 and the errors disappeared
