SAMSUNG TV wifi connection
I have different situation with my samsung smart tv.
Its brand new one 32", and latest software installed.
I have also mikrotik RB433 with v6.19 os
From 2 months i cannot connect samsung tv and my wifi module (2,4 Ghz).
Previously this setup has working fine, and i have no problems at all.
Something changes (i cannot confirm what it was), and my Samsung TV cannot connect via WiFi to my network.
When i use wired connection, everything is OK, so its not Samsung fault.
Today i use my phone (galaxy S6) to create mobile network, and Samsung TV connect to it and i can browse network perfectly.
So only reasonable answer is my WiFi settings are wrong, and that why i cannot connect my TV to Mikrotik network.
Can you guys help me with setup wifi network to allow my TV to connect ?
  1. When i connect tv to wifi there is no response in logs
  2. I tryed to change channels from 1 to 11, nothing helps.
  3. security profile change to open also not helps
  4. Other devices (androids, iphones, ipads, laptops etc working fine).
    I`m not a mikrotik pro.
8 years later, the same problem exists. Hap ac2 Version 7.10.2. The Samsung TV sees the wifi name, but cannot connect, timeout error. Anyone can advise what to do, please?
16:48:11 wireless,info 7C:64:56:A9:E6:DA@wlan1: connected, signal strength -44
16:48:27 wireless,info 7C:64:56:A9:E6:DA@wlan1: disconnected, received disassoc: sending station leaving (8), signal strength -44
16:49:27 wireless,info 7C:64:56:A9:E6:DA@wlan1: connected, signal strength -46
16:49:45 wireless,info 7C:64:56:A9:E6:DA@wlan1: disconnected, received disassoc: sending station leaving (8), signal strength -46
Upgraded to 7.11, enabled in bridge interface DHCP snooping, still not working. Even with WPS not getting IP:
17:18:51 wireless,info wlan2: WPS virtual button pushed
17:18:51 wireless,info wlan1: WPS virtual button pushed
17:19:12 wireless,info 7E:6C:84:53:D0:7E@wlan1: connected, signal strength -53
17:19:12 wireless,info 7E:6C:84:53:D0:7E@wlan2: disconnected, registered to other interface, signal strength -84
17:19:24 wireless,info wlan2: WPS association from 7C:64:56:A9:E6:DA
17:19:24 wireless,info 7C:64:56:A9:E6:DA@wlan2: connected, signal strength -42
17:19:24 wireless,info wlan2: WPS of 7C:64:56:A9:E6:DA started, associated
17:19:26 wireless,info wlan2: WPS of 7C:64:56:A9:E6:DA, received info: ' ' / / /
17:19:26 wireless,info wlan2: WPS of 7C:64:56:A9:E6:DA, do registration
17:19:26 wireless,info wlan2: WPS of 7C:64:56:A9:E6:DA complete
17:19:26 wireless,info wlan2: WPS button reset
17:19:26 wireless,info 7C:64:56:A9:E6:DA@wlan2: disconnected, WPS complete, signal strength -42
17:19:26 wireless,info 7C:64:56:A9:E6:DA@wlan2: connected, signal strength -41
17:19:26 wireless,info 7C:64:56:A9:E6:DA@wlan2: disconnected, received disassoc: sending station leaving (8), signal strength -41
17:20:51 wireless,info wlan1: WPS button reset
I presume you have tested the same WiFi SSID with other devices and it works OK? And you use WPA2-PSK?
Please use “/interface/wireless/export” in a terminal window and cut/paste the result here.
(DO NOT make screenshots of winbox windows etc)
Yes, other devices work fine (PC, 6 different android phones).
Yes, i use default security profile (wpa2-psk).
[admin@mikro] > /interface/wireless/export
# 2023-08-18 21:12:51 by RouterOS 7.11
# software id = **ELIDED**
# model = RBD52G-5HacD2HnD
# serial number = xxx
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    katim wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=katim wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk,wpa2-eap comment=wpapass2021 eap-methods="" mode=dynamic-keys name=wpa-only supplicant-identity=""
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=freeprofile supplicant-identity=""
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" group-ciphers=tkip,aes-ccm mode=dynamic-keys name=any-auth \
    supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile-test supplicant-identity=""
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:01 master-interface=wlan1 max-station-count=200 \
    multicast-buffering=disabled name=2test security-profile=profile-test ssid=test wds-cost-range=0 wds-default-cost=0 wps-mode=\
    disabled
add disabled=no keepalive-frames=disabled mac-address=DE:2C:6E:01:5B:37 master-interface=wlan1 multicast-buffering=disabled name=\
    freewlan2 security-profile=freeprofile ssid=freed wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=DE:2C:6E:01:5B:38 master-interface=wlan2 multicast-buffering=disabled name=\
    freewlan5 security-profile=freeprofile ssid=freed wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
Ok, I see that you have profiles with authentication-types=wpa2-psk,wpa2-eap (both PSK and EAP in a single profile) and that is usually problematic, but it looks like you are not using those.
The settings look OK to me, almost everything is at default.
You could try to temporarily add a profile with mode “none” (open) and check if it can connect then, to see if it is an authentication issue or something entirely different.
Could it be that RouterOS picks a channel that’s not supported by the TV? Might happen if you have an international version of Mikrotik and other devices but some regional restricted TV. Have you tried separate SSID from 2.4 and 5 networks to force Samsung TV on 2.4? Have you tried changing channel width (e.g. to 40Mhz only) on the 5 network?
