Ok guys, I need a shoulder.
I’ve got this picture:
DSL - Windows Machine - MT - LAN
On Windows Machine, there is DVB card and DSL is atached to eth1. DSL is connecting throw PPPoE. I cannot setup the MT i do:
- Setup IPs (doesn’t matter here).
- Setup DHCP (doesn’t matter here).
- I setup deafult gateway 192.168.0.1 (the Windows eth2 ip).
- I setup proxy with parent proxy 192.168.0.1.
- I make it transperant with dst-nat.
- I make src-nat for LAN IPs.
After all I can ping the gateway, but I cannot ping the dsl DNSs. I think the problem is the windows software. There is ccProxy on it. And nothing more.
What is the resolution of the problem? If I atach dsl to the MT. Should this work.
- Setup default gateway throw PPPoE.
- Make src-nat for Lan IPs (i think here they should have i-net throw dsl, without problem).
- Start Proxy with parent proxy 192.168.0.1.
- Make dst-nat for 80 to 8081 (8081 is the ccproxy port which is route to 127.0.0.1:8080 the DVB proxy).
- Will I be happy?
