Scan wireless networks using API for Java
I am trying to make one app for remote scanning but i can´t find the correct command. Using the CLI I use this one:
interface wireless scan number=0
With the API I have tried with this one:
ret.sendCommand(“/interface/wireless/scan=.number=*2”);
When *2 i get from this command:
interface wireless
:put [find];
But unfortunately the answer is:
Mikrotik:
!trap
=message=no such command
Mikrotik:
!done
Does anyone know what is the correct command?
Thank you!
command should be
=.id=*2
that is, if you want to do scan with interface that .id number is *2 and the item exist.
Better get .id using API to get the permanent static item number.
or, just use this:
=.id=wlan1
yes, you can use item name to identify it, just check before you use that, as i have tested a lot of name uses as .id value, but i cannot be 100% sure i have tested them all.
          ret.sendCommand("/interface/wireless/scan"
               + "=.id=wlan1");
The same response:
run:
Mikrotik:
!trap
Mikrotik:
!done
