I had two scheduler events on old MT box, and one isn’t working after moving to new box.
Doesn’t print file now:
/queue simple print stats file stats
Works fine still:
/queue simple reset-counters-all
I can execute the command from console and it makes the file, but not when scheduler executes.
I’ve created new scheduler entry from scratch and it will not either.
Don’t know if there’s any way to make log entry to show error?
I’m wondering if this an issue with 3.23. (This is the first time I’ve tried on 3.23)
I’ve also tried running script with the same command, and it will not execute either
It only works from the command line on 3.23
I created scheduler event on several MT boxes with 3.22 and it works fine.
