I want to automatically run a script in my mikrotik device every time i log in via web interface
anybody know how to do it???
I’ve done something similar that checks for new/failed logins, and then sends email: http://forum.mikrotik.com/t/is-it-possible-to-run-a-script-on-login/55422/1 It could be easily modified. Use the scheduler to run the script every X seconds (however often you want it to check)
If you only want to monitor web logins, change this line of the script to:
:local currentBuf [ :toarray [ /log find message~“\blogged in\b.*\bvia web\b$” ] ] ;
thank you,
but is there any other way to do it without to use scheduler?
I have not found another way. It would be nice to have a way to run a script on login similar to the Hotspot User Profiles
I expected that there is NO other way to do it, except script-scheduler.
True, it would be very helpful if we could run a script similar like Hotspot login.
Anyway, i did it with script-scheduler.
Thanks for your time.
