Script Contents Run Manually but Not from Run Script Button
Hello. I have this script, which runs fine when I copy/paste it into a terminal window, but doesn't seem to run when I click on the Run Script button in Winbox (the variables referenced are manually created global variables for testing).
:if ($RadIncReq>$RadIncReqLast) do={
/tool fetch mode=https url="https://hooks.slack.com/services/real-token-removed" http-method=post http-data="payload={"attachments":[{"color":"#f54242","pretext":"ALARM","callback_id":"dude_alarm","text": "ROUTER-BNG - Incoming RADIUS Requests are Incrementing"}]}";
/log info "**** Incoming RADIUS Requests are Incrementing****";
When I copy/past the above in this exact form, I get the log entry and the message in Slack. When I click Run Script button, I get neither.
Here's the actual export:
/system script
add dont-require-permissions=no name=CheckRadIncRequests owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":if ($RadIncReq>$RadIncReqLast) do={\r
\n/tool fetch mode=https url="https://hooks.slack.com/services/real-token-removed\" http-method
=post http-data="payload={\"attachments\":[{\"color\":\"#f54242\",\"pretext\":\"ALARM\",\"callback_
id\":\"dude_alarm\",\"text\": \"ROUTER-BNG - Incoming RADIUS Requests are Incrementing\"}]}";\r
\n/log info "**** Incoming RADIUS Requests are Incrementing****";\r
\n}"
Here's the actual environment:
/system script environment> print
NAME VALUE
0 RadIncReq 9
1 RadIncReqLast 8
I'm sure I'm missing something simple, thanks in advanced!
Simple to solve.
You need to declare the global variable before it can be seen by a script, so change to:
:global RadIncReq
:global RadIncReqLast
	/tool fetch mode=https url="https://hooks.slack.com/services/real-token-removed" http-method=post http-data="payload={\"attachments\":[{\"color\":\"#f54242\",\"pretext\":\"ALARM\",\"callback_id\":\"dude_alarm\",\"text\": \"ROUTER-BNG - Incoming RADIUS Requests are Incrementing\"}]}"
PS use code tags </> when posting codes and ; are not needed on end of each line, only between multiple commands on same line.
Thanks so much for the quick reply, I appreciate it. I will use code tags next time, too.
