script for adding batch users
I need a script to add batch users with my own username and password, up-time-limit and credit-time. I’d been unable to do that. Anyone can help in this matter.
thnx
If I correctly understand you, you want to add batch of users, that will have the same uptime-limit and credit.
To do the following,
  • login to the User Manager http://router_IP/userman
  • select ‘Users’ menu;
  • ‘Add batch’;
  • specify the number of clients, uptime limit for them and credit options (credit should be preconfigured).
Users will be added with different username password and the same uptime and credit settings.
writing script to add a user. Now i got it. I was having problem with credit keyword then i found out the keyword add-credit.
thnx
Hi all,
I apologize in advance if this is a stupid question, but I wanted to log in as userman from http://router_ip/userman, and I don’t know which username and password have to be used to log in.
Anyone can help me?
Thanks!
Giovanni
do as this link from console first:
than go to your browser http://router/userman manage your user for.
or visit this: RouterOS - RouterOS - MikroTik Documentation
regards
Hasbullah.com
