ashpri
September 23, 2022, 1:22am
1
Recursive failover has been working perfect for my connection with 2 ISPs. Last week my main ISP experienced intermittent issues. You could still ping but it was intermittent with latency spikes. I ended up having to disable (renumber) the route manually.
How would I apply recursive failover by checking for packet loss?
I suppose the script logic would be:
Check 8.8.8.8 (recursive for ISP1) & 8.8.4.4 (recursive for ISP2)
Ping 8.8.8.8 or 8.8.4.4 ten times
If packet loss >=20% then find route by comment and disable
If packet loss <20% then find route by comment and enable
Are there past topics that you can refer me to.
Thank you.
ashpri
September 23, 2022, 1:39am
2
That logic would not work. Once you disable a route you can’t check whether it is back to normal.
Updated logic:
Ping 8.8.8.8 (recursive for ISP-1) 20 times
If packet loss = 0%,
do nothing
Else If packet loss >= 20% and route to ISP-1 (find by comment) distance = 1,
find route to ISP-1 (find by comment) and change distance to 91
Else if packet loss = 0% and route to ISP-1 distance != 1,
find route to ISP-1 and change distance to 1
I would then have a similar script for ISP-2 except the distances would be different.
Do you agree with the script logic?
ashpri
September 23, 2022, 6:33am
3
FYI this is the relevant screen in fortigate to achieve the above.
You could always do something like this:
:if ([/ping XXX.XXX.XXX.XXX count=100] = 0) do={
you can change it to greater than or less than, so if you send 100 pings and the returned packets are 95 or less you can do something.
I think i saw something about ROS v7 having a new netwatch tool that can do packet loss detection.
dfdf
November 25, 2022, 9:12pm
6
:local "stat_period" (5*60);
:local "traffic";
:local "tx-packets-per-second";
:local "rx-packets-per-second";
:local "packet_tx_drops_rate";
:local "packet_rx_drops_rate";
#:local "packet_tx_errors_rate";
#:local "packet_rx_errors_rate";
:for "count" from=1 to=$"stat_period" do={
:set $"traffic" [/interface/monitor-traffic interface=current_wan as-value once];
:set $"packet_tx_drops_rate" ($"packet_tx_drops_rate"+($"traffic"->"tx-queue-drops-per-second"));
:set $"packet_rx_drops_rate" ($"packet_rx_drops_rate"+($"traffic"->"rx-drops-per-second"));
# :set $"packet_tx_errors_rate" ($"packet_tx_errors_rate"+($"traffic"->"tx-errors-per-second"));
# :set $"packet_rx_errors_rate" ($"packet_rx_errors_rate"+($"traffic"->"rx-errors-per-second"));
:set $"tx-packets-per-second" ($"tx-packets-per-second"+($"traffic"->"tx-packets-per-second"));
:set $"rx-packets-per-second" ($"rx-packets-per-second"+($"traffic"->"rx-packets-per-second"));
:delay 1s;
:set $"packet_tx_drops_rate" (($"packet_tx_drops"/$"stat_period")*100)/($"tx-packets-per-second");
:set $"packet_rx_drops_rate" (($"packet_rx_drops"/$"stat_period")*100)/($"rx-packets-per-second");
#:set $"packet_tx_errors_rate" ($"packet_tx_errors_rate"/$"stat_period");
#:set $"packet_rx_errors_rate" ($"packet_rx_errors_rate"/$"stat_period");
than evaluate failover criteria based on collected values and switch gateway by manipulating routing table…
i think new implementation of netwatch in Routeros 7.4 and later can help
https://help.mikrotik.com/docs/display/ROS/Netwatch
vklpt
November 29, 2022, 4:45pm
8
