Script NTOP to stop DDOS
Does anyone know how to use ntop to stop a DDOS? We have ntop setup and it is working perfectly. Alerts work also, but i would like to be able to trigger a mikrotik to add the IP that has the alert to be added to the BGP - Networks tab of a mikrotik.
Alerts for working
https://www.ntop.org/guides/ntopng/basic_concepts/alerts.html#user-configurable-thresholds
Alert endpoints
https://www.ntop.org/guides/ntopng/web_gui/alerts.html#alert-endopints
Thanks,
Maybe you would like to check FastNetMon. It has a plugin for Mikrotik …
We are looking at that. We were just trying to figure out if NTOP can do it instead, since we already run NTOP.
Does anyone have a good walk through on how to get fast net Mon working?
Hello
You have a quick start to using Fastnetmon Advanced (my advice is use this version) at https://fastnetmon.com/advanced-install-guide/
You can use a trial license to test it.
Also, you can use our panel FNM Manager to control it: https://fastnetmon.mkesolutions.net
There are a community version, but doesn’t support IPv6 and another features.
Regards
M.
