Script or process for sanitizing exports?
What process does everyone follow for sanitizing their exports?
Mine are full of sensitive information such as wireguard keys, passwords, email address, local and dynamic dns entries/hostnames, serial numbers, mac addresses, dyndns login info, ftp upload info, ip-sec secret, and probably more.
I always seem to miss some when I do it by hand (even using an editor with search and replace) because the format for these pieces of data is different in different places of the rsc.
If you do /export hide-sensitive, secrets aren’t exported that way. Dynamic entries aren’t exported with /export too.
I wish that worked, but it doesn’t.
I issued:
/export hide-sensitive terse and the following came out.
I replaced all the sensitive informaiton with XXXXX (5 capital letters X). There are 99 such replacements and I left many many mac addresses.
# 2024-10-06 08:27:31 by RouterOS 7.14.2
# software id = 2KBD-7ZZB
# model = RB5009UPr+S+
# serial number = HDA0XXXXX
/interface bridge add admin-mac=18:FD:XXXXX auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface ethernet set [ find default-name=ether1 ] comment=WAN poe-out=off
/interface ethernet set [ find default-name=ether2 ] comment="Switch CSS 24" poe-out=off
/interface ethernet set [ find default-name=ether3 ] comment="JRS PC port 3" poe-out=off
/interface ethernet set [ find default-name=ether4 ] comment="hAP 16" poe-out=off
/interface ethernet set [ find default-name=ether5 ] comment="15 wall port 5 -- Proxmox" poe-out=off
/interface ethernet set [ find default-name=ether6 ] comment="MOCA adapter" poe-out=off
/interface ethernet set [ find default-name=ether7 ] poe-out=off
/interface ethernet set [ find default-name=ether8 ] poe-out=off
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:DE:XXXXX name=eoip-tunnel-to-76 remote-address=XXXXX.sn.mynetname.net tunnel-id=76
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:DE:XXXXX name=eoip-tunnel-to-125 remote-address=XXXXX.dyndns.org tunnel-id=125
/interface eoip add disabled=yes mac-address=02:68:XXXXX name=eoip-tunnel-to-212-ax3 remote-address=192.168.2.5 tunnel-id=101
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:DE:XXXXX name=eoip-tunnel-to-255 remote-address=XXXXX.sn.mynetname.net tunnel-id=255
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:54:XXXXX name=eoip-tunnel-to-355 remote-address=XXXXX.sn.mynetname.net tunnel-id=355
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:DE:XXXXX name=eoip-tunnel-to-371 remote-address=XXXXX.dyndns.org tunnel-id=371
/interface eoip add allow-fast-path=no disabled=yes mac-address=02:66:XXXXX name=eoip-tunnel-to-629 remote-address=XXXXX.dyndns.org tunnel-id=629
/interface wireguard add listen-port=51820 mtu=1420 name=212-Wireguard
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface list add name=MANAGE
/interface list add name=DHCPdisabled
/iot lora servers add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
/iot lora servers add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
/iot lora servers add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=UDP
/iot lora servers add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=UDP
/iot lora servers add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=UDP
/iot lora servers add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
/iot lora servers add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
/iot lora servers add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
/iot mqtt brokers add address=192.168.0.103 client-id=192.168.2.2 name=HA password=XXXXX username=mqtt
/iot mqtt brokers add address=192.168.0.162 auto-connect=yes name="Home Assistant" password=XXXXX username=mqtt
/ip kid-control add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d wed=0s-1d
/ip pool add name=dhcp ranges=192.168.2.100-192.168.2.200
/ip dhcp-server add address-pool=dhcp interface=bridge lease-script="\r\
    \n/system\r\
    \n:local cdate [clock get date] \r\
    \n:local yyyy  [:pick \$cdate 0  4]\r\
    \n:local MM    [:pick \$cdate 5  7]\r\
    \n:local dd    [:pick \$cdate 8 10]\r\
    \n\r\
    \n:local thistime [/system clock get time]\r\
    \n:local thishour [:pick \$thistime 0 2]\r\
    \n:local thisminute [:pick \$thistime 3 5]\r\
    \n:local thissecond [:pick \$thistime 6 8]\r\
    \n:local identitydatetime \"\$[identity get name]_\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\"\r\
    \n:local datetime \"\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\"\r\
    \n:local systemname \"\$[identity get name]\"\r\
    \n\r\
    \n#:if (\$leaseBound=1) do={\r\
    \n\r\
    \n#  :log info \"testing after condition BOUND\" }\r\
    \n\r\
    \n#:if  ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActMAC]!=\"\") do={\r\
    \n\r\
    \n#  :log info \"testing after condition DYNAMIC\"}\r\
    \n\r\
    \n\r\
    \n:if  ((\$leaseBound=1)  && ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActMAC]!=\"\") && ([/ip dhcp-server lease find where comment mac-address=\$leaseActMAC]=\"\")) do={\r\
    \n\r\
    \n#    :log info \"testing after conditions BOUND and DYNAMIC and EMPTY COMMENT\" \r\
    \n\r\
    \n:local recipient \"jXXXXX\"\r\
    \n\r\
    \n #   :tool e-mail send to=\$recipient subject=\"\$systemname DHCP Lease Assigned to \$leaseActMAC\" body=\"MAC address \$leaseActMAC received IP address \$leaseActIP with a hostname of \$[/ip/dhcp-server/lease/get value-name=host-name [find where mac-address=\$leaseActMAC]] from DHCP Server \$leaseServerName on \$datetime from \$systemname with comment \$[/ip/dhcp-server/lease/get value-name=comment [find where mac-address=\$leaseActMAC]]\"\r\
    \n\r\
    \n\r\
    \n#    :log info \"Sent DHCP alert for MAC \$leaseActMAC\"\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n" lease-time=1d name=defconf
/ip smb users set [ find default=yes ] disabled=yes
/system logging action set 3 remote=192.168.0.13
/system logging action add name=logserver remote=192.168.0.112 remote-port=51400 target=remote
/zerotier set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=zt1 port=9993
/container config set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/interface bridge filter add action=drop chain=forward disabled=yes dst-port=67-68 in-interface-list=DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Forward mac-protocol=ip out-interface-list=DHCPdisabled src-port=67-68
/interface bridge filter add action=drop chain=input disabled=yes dst-port=67-68 in-interface-list=DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Input mac-protocol=ip src-port=67-68
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=ether7 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
/ip firewall connection tracking set udp-timeout=10s
/ip neighbor discovery-settings set discover-interface-list=all
/ipv6 settings set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes forward=no max-neighbor-entries=8192
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ether1 list=WAN
/interface list member add interface=bridge list=MANAGE
/interface list member add disabled=yes interface=ether1 list=MANAGE
/interface list member add interface=212-Wireguard list=LAN
/interface list member add interface=212-Wireguard list=MANAGE
/interface list member add interface=212-Wireguard list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-76 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-125 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-212-ax3 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-255 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-355 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-371 list=DHCPdisabled
/interface list member add interface=eoip-tunnel-to-629 list=DHCPdisabled
/interface wireguard peers add allowed-address=10.10.100.8/32 comment="JRS Laptop" interface=212-Wireguard public-key="XXXXX"
/interface wireguard peers add allowed-address=10.10.100.2/32,192.168.88.0/24,10.10.100.40/32,192.168.40.0/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=52820 interface=212-Wireguard persistent-keepalive=40s public-key="XXXXX="
/interface wireguard peers add allowed-address=10.10.100.9/32 comment="JRS iPhone" interface=212-Wireguard public-key="XXXXX="
/interface wireguard peers add allowed-address=10.10.100.12/32,192.168.20.0/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=51821 interface=212-Wireguard persistent-keepalive=40s public-key="XXXXX="
/interface wireguard peers add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=51833 interface=212-Wireguard persistent-keepalive=40s public-key="Q8CPJm+/XXXXX="
/interface wireguard peers add allowed-address=10.10.100.60/32,192.168.1.0/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=51835 interface=212-Wireguard persistent-keepalive=40s public-key="XXXXX+XXXXX="
/interface wireguard peers add allowed-address=10.10.100.30/32,192.168.30.1/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=51830 interface=212-Wireguard persistent-keepalive=40s public-key="XXXXX="
/interface wireguard peers add allowed-address=10.10.90.0/24 comment="BI PC WG APP" endpoint-port=51820 interface=212-Wireguard public-key="XXXXX/XXXXX="
/interface wireguard peers add allowed-address=10.10.100.1/32,192.168.2.2/24 comment="212 (local, just for reference);   192.168.2.2" disabled=yes endpoint-address=XXXXX.dyndns.org endpoint-port=51820 interface=212-Wireguard public-key="XXXXX/XXXXX="
/interface wireguard peers add allowed-address=10.10.100.100/32 comment="JRS Laptop 201" disabled=yes interface=212-Wireguard public-key="XXXXX/XXXXX="
/interface wireguard peers add allowed-address=10.10.100.101/32 endpoint-port=51840 interface=212-Wireguard public-key="N/XXXXX/86S/XXXXX="
/interface wireguard peers add allowed-address=10.10.100.70/32,192.168.70.0/24 comment=XXXXX endpoint-address=XXXXX.dyndns.org endpoint-port=51870 interface=212-Wireguard persistent-keepalive=40s public-key="XXXXX="
/interface wireguard peers add allowed-address=10.10.100.99/32,192.168.2.0/24 comment="JRS Laptop 2023" interface=212-Wireguard private-key="XXXXX+XXXXX//vOc9p2Q=" public-key="XXXXX+XXXXX="
/interface wireguard peers add allowed-address=10.10.100.53/32,192.168.0.0/24 client-listen-port=51840 comment="WG Proxmox Win11" endpoint-address=XXXXX.dyndns.org endpoint-port=51844 interface=*12 public-key="XXXXX+8BNw0IP+XXXXX="
/interface wireguard peers add allowed-address=10.10.100.15/32 comment=AX endpoint-address=10.0.0.1 endpoint-port=51860 interface=212-Wireguard persistent-keepalive=40s public-key="HDA08A4MAZH/XXXXX="
/ip address add address=192.168.2.2/24 comment=defconf interface=bridge network=192.168.2.0
/ip address add address=10.10.100.1/24 interface=212-Wireguard network=10.10.100.0
/ip cloud set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server alert add alert-timeout=12h disabled=no interface=bridge on-alert="/system script add name=rogue-dhcp source=\94:log warning message=\\\94Rogue DHCP server detected!\\\94\94"
/ip dhcp-server alert add alert-timeout=30m interface=bridge on-alert=rogue-dhcp
/ip dhcp-server lease add address=192.168.2.100 comment=TV15 mac-address=78:6A:1F:8D:F9:C8 server=defconf
/ip dhcp-server lease add address=192.168.2.121 client-id=1:da:f3:68:be:3f:b comment="Ipad SRN" mac-address=DA:F3:68:BE:3F:0B server=defconf
/ip dhcp-server lease add address=192.168.2.102 comment=STB mac-address=78:6A:1F:8D:FC:B4 server=defconf
/ip dhcp-server lease add address=192.168.2.101 comment=STB mac-address=78:6A:1F:8D:FC:0F server=defconf
/ip dhcp-server lease add address=192.168.2.103 comment=STB mac-address=A0:68:7E:4D:D0:4B server=defconf
/ip dhcp-server lease add address=192.168.2.138 client-id=1:30:c9:ab:17:71:59 comment=MFCL3770CDW lease-time=3d18h mac-address=30:C9:AB:17:71:59 server=defconf
/ip dhcp-server lease add address=192.168.2.107 client-id=1:94:e7:b:29:30:e7 comment=JRSLaptopASUS mac-address=94:E7:0B:29:30:E7 server=defconf
/ip dhcp-server lease add address=192.168.2.141 client-id=1:c2:5d:7f:1f:4c:f5 comment="JRS iPhone" mac-address=C2:5D:7F:1F:4C:F5 server=defconf
/ip dhcp-server lease add address=192.168.2.106 client-id=1:18:fd:74:cf:7f:5c comment=RB5009 mac-address=18:FD:74:CF:7F:5C server=defconf
/ip dhcp-server lease add address=192.168.2.109 client-id=1:0:6b:9e:d1:24:f3 comment="Vizio on 15" mac-address=00:6B:9E:D1:24:F3 server=defconf
/ip dhcp-server lease add address=192.168.2.147 comment=TV mac-address=3C:59:1E:F4:02:EF server=defconf
/ip dhcp-server lease add address=192.168.2.122 client-id=1:d4:90:9c:d8:66:99 comment=Homepod mac-address=D4:90:9C:D8:66:99 server=defconf
/ip dhcp-server lease add address=192.168.2.191 comment="TV 15 SRN Office" mac-address=3C:59:1E:F4:3C:CB server=defconf
/ip dhcp-server lease add address=192.168.2.199 client-id=1:c8:63:f1:f1:9f:44 comment=Playstation mac-address=C8:63:F1:F1:9F:44 server=defconf
/ip dhcp-server lease add address=192.168.2.119 client-id=1:88:e9:fe:6e:97:9d comment=ThomasMBP mac-address=88:E9:FE:6E:97:9D server=defconf
/ip dhcp-server lease add address=192.168.2.128 comment=MBR65TV mac-address=34:51:80:C8:BB:2C server=defconf
/ip dhcp-server lease add address=192.168.2.200 client-id=1:0:4:20:f9:31:d2 comment=HarmonyHub lease-time=3d18h mac-address=00:04:20:F9:31:D2 server=defconf
/ip dhcp-server lease add address=192.168.2.114 client-id=1:46:b4:96:5e:1a:1b comment="Thomas iPhone" mac-address=46:B4:96:5E:1A:1B server=defconf
/ip dhcp-server lease add address=192.168.2.176 client-id=1:18:3:73:3a:63:19 mac-address=18:03:73:3A:63:19 server=defconf
/ip dhcp-server lease add address=192.168.2.142 client-id=1:4e:fe:92:a6:40:cd comment=SRNAppleWatch mac-address=4E:FE:92:A6:40:CD server=defconf
/ip dhcp-server lease add address=192.168.2.124 client-id=1:2c:6f:c9:5f:bc:eb comment=Printer mac-address=2C:6F:C9:5F:BC:EB server=defconf
/ip dhcp-server lease add address=192.168.2.173 client-id=1:24:ee:9a:54:9a:e8 comment=NC-LT-SN20 mac-address=24:EE:9A:54:9A:E8 server=defconf
/ip dhcp-server lease add address=192.168.2.117 client-id=1:b4:22:0:95:59:8a comment=Printer mac-address=B4:22:00:95:59:8A server=defconf
/ip dhcp-server lease add address=192.168.2.127 client-id=ff:a1:71:46:7d:0:1:0:1:2c:cb:11:8c:a:25:a1:71:46:7d comment="Debian LXC under Proxmox" mac-address=0A:25:A1:71:46:7D server=defconf
/ip dhcp-server lease add address=192.168.2.110 client-id=1:64:49:7d:61:ae:2c comment=JRS-Laptop-2023 mac-address=64:49:7D:61:AE:2C server=defconf
/ip dhcp-server lease add address=192.168.2.166 comment="15 TV" mac-address=B0:A7:37:75:B6:60 server=defconf
/ip dhcp-server lease add address=192.168.2.105 client-id=1:c4:17:fe:43:33:7 comment=Susans-iPhone mac-address=C4:17:FE:43:33:07 server=defconf
/ip dhcp-server lease add address=192.168.2.108 client-id=1:0:5:cd:19:3c:7 comment="Denon AVR" mac-address=00:05:CD:19:3C:07 server=defconf
/ip dhcp-server lease add address=192.168.2.116 client-id=1:ea:c1:5:82:99:7c comment="SRN iphone" mac-address=EA:C1:05:82:99:7C server=defconf
/ip dhcp-server lease add address=192.168.2.120 client-id=1:96:4e:a5:1a:a9:74 comment="Thomas iPad large" mac-address=96:4E:A5:1A:A9:74 server=defconf
/ip dhcp-server lease add address=192.168.2.123 client-id=1:54:6c:eb:7b:a2:c3 comment="Thomas Acer" mac-address=54:6C:EB:7B:A2:C3 server=defconf
/ip dhcp-server lease add address=192.168.2.113 client-id=1:18:fd:74:38:81:2b comment=hEX mac-address=18:FD:74:38:81:2B server=defconf
/ip dhcp-server lease add address=192.168.2.112 client-id=1:fc:aa:81:2a:1f:b4 comment="JRS iPhone 2023" mac-address=FC:AA:81:2A:1F:B4 server=defconf
/ip dhcp-server lease add address=192.168.2.118 client-id=1:36:41:ef:17:d0:c9 comment="SRN Apple Watch" mac-address=36:41:EF:17:D0:C9 server=defconf
/ip dhcp-server lease add address=192.168.2.115 client-id=1:16:31:50:11:6b:cf comment="Susan iPad" mac-address=16:31:50:11:6B:CF server=defconf
/ip dhcp-server lease add address=192.168.2.126 client-id=1:7a:49:88:57:e9:14 comment="NOT any Thomas or Susan's Device" mac-address=7A:49:88:57:E9:14 server=defconf
/ip dhcp-server lease add address=192.168.2.130 client-id=1:3c:6:30:20:1:70 comment="Padan\?" mac-address=3C:06:30:20:01:70 server=defconf
/ip dhcp-server lease add address=192.168.2.133 client-id=1:f6:b9:88:dd:23:1a comment="\?\?\?\?\?" mac-address=F6:B9:88:DD:23:1A server=defconf
/ip dhcp-server lease add address=192.168.2.134 client-id=1:be:22:c3:46:12:33 mac-address=BE:22:C3:46:12:33 server=defconf
/ip dhcp-server lease add address=192.168.2.111 client-id=1:c8:f0:9e:e8:8a:e4 comment="THR316D T BR" mac-address=C8:F0:9E:E8:8A:E4 server=defconf
/ip dhcp-server lease add address=192.168.2.131 client-id=1:d6:a9:86:b1:c9:3e comment="SRN iwatch" mac-address=D6:A9:86:B1:C9:3E server=defconf
/ip dhcp-server lease add address=192.168.2.129 client-id=1:22:bc:d8:7f:66:fd comment="Thomas -- " mac-address=22:BC:D8:7F:66:FD server=defconf
/ip dhcp-server lease add address=192.168.2.132 client-id=1:3c:a6:f6:1f:87:ac mac-address=3C:A6:F6:1F:87:AC server=defconf
/ip dhcp-server lease add address=192.168.2.139 client-id=1:1a:b9:14:b4:55:ea comment="Rachel phone" mac-address=1A:B9:14:B4:55:EA server=defconf
/ip dhcp-server lease add address=192.168.2.140 client-id=1:68:1d:ef:38:e5:9b comment="Mini-PC from aliexpress" mac-address=68:1D:EF:38:E5:9B server=defconf
/ip dhcp-server lease add address=192.168.2.125 client-id=1:2e:ef:fe:36:a1:5 comment="Thomas iPhone" mac-address=2E:EF:FE:36:A1:05 server=defconf
/ip dhcp-server lease add address=192.168.2.137 client-id=1:c8:7f:54:5a:69:13 comment="JRS 2024 Desktop" mac-address=C8:7F:54:5A:69:13 server=defconf
/ip dhcp-server lease add address=192.168.2.144 client-id=1:3c:6:30:c:ee:88 mac-address=3C:06:30:0C:EE:88 server=defconf
/ip dhcp-server lease add address=192.168.2.154 comment=65TCLRokuTV mac-address=08:C3:B3:DF:26:62 server=defconf
/ip dhcp-server lease add address=192.168.2.171 comment=49TCLRokuTV mac-address=0C:62:A6:1E:8B:18 server=defconf
/ip dhcp-server lease add address=192.168.2.149 client-id=1:68:1d:ef:3a:da:e0 comment="T8-Mini-PC-26NNQ3ARVB1\r\
    \n" mac-address=68:1D:EF:3A:DA:E0 server=defconf
/ip dhcp-server lease add address=192.168.2.143 client-id=1:b2:38:c:90:fe:4 comment=MFC-L2550 mac-address=B2:38:0C:90:FE:04 server=defconf
/ip dhcp-server lease add address=192.168.2.161 client-id=1:ec:da:3b:d1:92:3c comment="Presence sensor Screek D1923C" mac-address=EC:DA:3B:D1:92:3C server=defconf
/ip dhcp-server lease add address=192.168.2.190 mac-address=48:55:19:F0:73:12 server=defconf
/ip dhcp-server lease add address=192.168.2.150 client-id=1:84:57:33:9b:83:85 mac-address=84:57:33:9B:83:85 server=defconf
/ip dhcp-server lease add address=192.168.2.162 client-id=1:7c:4b:26:5d:6:be mac-address=7C:4B:26:5D:06:BE server=defconf
/ip dhcp-server lease add address=192.168.2.153 client-id=1:70:d8:c2:4c:54:64 comment="Beelink SER 212 Dining Table" mac-address=70:D8:C2:4C:54:64 server=defconf
/ip dhcp-server network add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.2 gateway=192.168.2.2 netmask=24
/ip dns set allow-remote-requests=yes cache-max-ttl=2d cache-size=4096KiB servers=8.8.4.4,8.8.8.8,9.9.9.9,1.1.1.1
/ip dns static add address=192.168.2.8 name=212-rb5009.212.local
/ip dns static add address=192.168.2.2 name=RB5009.212.local ttl=9w6d10h40m
/ip dns static add address=10.10.100.1 name=212.10.10.100.1.local ttl=9w6d10h40m
/ip dns static add address=192.168.2.100 comment="automatic-from-comment (magic comment)" name=TV15.212.local ttl=1h
/ip dns static add address=192.168.2.121 comment="automatic-from-comment (magic comment)" name="Ipad SRN.212.local" ttl=9w6d10h40m
/ip dns static add address=192.168.2.138 comment="automatic-from-comment (magic comment)" name=MFCL3770CDW.212.local ttl=9w6d10h40m
/ip dns static add address=192.168.2.141 comment="automatic-from-comment (magic comment)" name="JRS iPhone.212.local" ttl=9w6d10h40m
/ip dns static add address=192.168.2.109 comment="automatic-from-comment (magic comment)" name="Vizio on 15.212.local" ttl=9w6d10h40m
/ip dns static add address=192.168.2.122 comment="automatic-from-comment (magic comment)" name=Homepod.212.local ttl=9w6d10h40m
/ip dns static add address=192.168.2.199 comment="automatic-from-comment (magic comment)" name=Playstation.212.local ttl=9w6d10h40m
/ip dns static add address=192.168.2.142 comment="automatic-from-comment (magic comment)" name=SRNAppleWatch.212.local ttl=9w6d10h40m
/ip dns static add address=192.168.2.22 name=JRS-PC.212.local
/ip dns static add address=192.168.2.102 comment="automatic-from-dhcp (magic comment)" name=Master-Bedroom.212.local ttl=1h40m
/ip dns static add address=192.168.2.103 comment="automatic-from-dhcp (magic comment)" name=Family-Room.212.local ttl=1h40m
/ip dns static add address=192.168.2.138 comment="automatic-from-dhcp (magic comment)" name=MFC-L3770.212.local ttl=1h40m
/ip dns static add address=192.168.2.147 comment="automatic-from-dhcp (magic comment)" name=212LR.212.local ttl=1h40m
/ip dns static add address=192.168.2.191 comment="automatic-from-dhcp (magic comment)" name=SRNOffice.212.local ttl=1h40m
/ip dns static add address=192.168.2.128 comment="automatic-from-dhcp (magic comment)" name=212MBR.212.local ttl=1h40m
/ip dns static add address=192.168.2.200 comment="automatic-from-dhcp (magic comment)" name=HarmonyHub.212.local ttl=1h40m
/ip dns static add address=192.168.2.124 comment="automatic-from-dhcp (magic comment)" name=BRW2C6FC95FBCEB.212.local ttl=1h40m
/ip dns static add address=192.168.2.173 comment="automatic-from-dhcp (magic comment)" name=NC-LT-SN20.212.local ttl=1h40m
/ip dns static add address=192.168.2.137 comment="automatic-from-dhcp (magic comment)" name=tasmota-E37677-5751.212.local ttl=1h40m
/ip dns static add address=192.168.2.117 comment="automatic-from-dhcp (magic comment)" name=BRNB4220095598A.212.local ttl=1h40m
/ip dns static add address=192.168.2.127 comment="automatic-from-dhcp (magic comment)" name=Debian.212.local ttl=1h40m
/ip dns static add address=192.168.2.110 comment="automatic-from-dhcp (magic comment)" name=JRS-Laptop-2023.212.local ttl=1h40m
/ip dns static add address=192.168.2.108 comment="automatic-from-dhcp (magic comment)" name=0005CD193C07.212.local ttl=1h40m
/ip dns static add address=69.202.199.148 name=XXXXX.dyndns.org
/ip firewall address-list add address=XXXXX.dyndns.org list=dynamic-WANIP
/ip firewall address-list add address=192.168.0.0/16 list=Authorized
/ip firewall address-list add address=10.10.100.0/24 list=Authorized
/ip firewall address-list add address=XXXXX.dyndns.org list=XXXXX
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="Loopback allow" dst-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="DROP DHCP on DHCPdisabled" dst-port=67-68 in-interface-list=DHCPdisabled log=yes protocol=udp src-port=67-68
/ip firewall filter add action=accept chain=input comment="Allow GRE for EoIP" protocol=gre
/ip firewall filter add action=accept chain=input comment="Allow incoming WG connections" dst-port=51820 protocol=udp
/ip firewall filter add action=accept chain=input comment="Allow Authorized" src-address-list=Authorized
/ip firewall filter add action=accept chain=input comment="Allow LAN" in-interface-list=LAN
/ip firewall filter add action=drop chain=input comment="drop all else"
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=accept chain=forward comment="Allow LAN to WAN" in-interface-list=LAN out-interface-list=WAN
/ip firewall filter add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
/ip firewall filter add action=accept chain=forward comment="Allows cross peer subnet traffic" in-interface=212-Wireguard out-interface=212-Wireguard
/ip firewall filter add action=accept chain=forward comment="Allow WG to subnet" dst-address=192.168.2.0/24 in-interface=212-Wireguard
/ip firewall filter add action=accept chain=forward comment="Allow all traffic out WG iface" out-interface=212-Wireguard
/ip firewall filter add action=drop chain=forward log=yes log-prefix="drop forward (all else)"
/ip firewall mangle add action=mark-connection chain=prerouting comment="Mark connection for hairpin" disabled=yes dst-address-list=dynamic-WANIP log=yes new-connection-mark="Hairpin NAT" passthrough=yes src-address=192.168.2.0/24
/ip firewall nat add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark="Hairpin NAT" dst-address=192.168.2.0/24 src-address=192.168.2.0/24
/ip firewall nat add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:81 dst-address-list=XXXXX dst-port=81 log-prefix="NAT FW destination XXXXX port 81" protocol=tcp to-addresses=192.168.0.101 to-ports=81
/ip firewall nat add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:8123 dst-address-list=XXXXX dst-port=8123 protocol=tcp to-addresses=192.168.0.162 to-ports=8123
/ip firewall nat add action=masquerade chain=srcnat comment="NEW defconf: masquerade" out-interface-list=WAN
/ip firewall nat add action=dst-nat chain=dstnat dst-address-list=dynamic-WANIP dst-port=8123 protocol=tcp to-addresses=192.168.2.176
/ip firewall nat add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark="Hairpin NAT" disabled=yes dst-address=192.168.2.0/24 src-address=192.168.2.0/24
/ip firewall nat add action=masquerade chain=srcnat comment="NEW defconf: masquerade" disabled=yes out-interface-list=WAN
/ip firewall nat add action=dst-nat chain=dstnat disabled=yes dst-address-list=dynamic-WANIP dst-port=8123 protocol=tcp to-addresses=192.168.2.176
/ip firewall nat add action=dst-nat chain=dstnat disabled=yes dst-address-list=dynamic-WANIP dst-port=5911 log=yes protocol=tcp to-addresses=192.168.2.139
/ip firewall nat add action=dst-nat chain=dstnat disabled=yes dst-port=51833 protocol=udp to-addresses=192.168.2.50
/ip route add comment=371 disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=355 disabled=yes distance=1 dst-address=192.168.0.0/24 gateway=*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=255 disabled=yes distance=1 dst-address=192.168.1.0/24 gateway=*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add disabled=yes distance=1 dst-address=192.168.5.0/24 gateway=*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=629 disabled=yes distance=1 dst-address=192.168.20.0/24 gateway=*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=355 disabled=no distance=1 dst-address=192.168.0.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=255 disabled=no distance=1 dst-address=192.168.1.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=355-Cameras disabled=no distance=1 dst-address=192.168.5.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=629 disabled=no distance=1 dst-address=192.168.20.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add disabled=no distance=1 dst-address=192.168.60.0/24 gateway=192.168.2.8 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=76 disabled=no distance=1 dst-address=192.168.30.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=371 disabled=no distance=1 dst-address=192.168.40.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add comment=125 disabled=no distance=1 dst-address=192.168.70.0/24 gateway=212-Wireguard pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip route add disabled=no distance=1 dst-address=10.0.0.0/24 gateway=192.168.2.5 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service set www-ssl disabled=no
/ip smb shares set [ find default=yes ] directory=/pub
/ip ssh set always-allow-password-login=yes forwarding-enabled=both
/snmp set enabled=yes trap-version=2
/system clock set time-zone-name=America/New_York
/system gps set set-system-time=no
/system identity set name=212RB5009
/system logging set 0 topics=info,!script
/system logging add topics=account
/system logging add topics=watchdog
/system logging add action=logserver prefix="serial= MikroTik" topics=hotspot
/system logging add action=logserver prefix="serial= MikroTik" topics=!debug,!packet,!snmp
/system logging add action=remote prefix="192.168.2.2 " topics=info
/system note set show-at-login=no
/system ntp client set enabled=yes
/system ntp server set enabled=yes
/system ntp client servers add address=216.239.35.4
/system ntp client servers add address=104.16.132.229
/system scheduler add disabled=yes interval=1d name=Daily on-event=dyndns policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-10-18 start-time=02:00:00
/system scheduler add disabled=yes interval=10m name=Route355255371 on-event="355 255 371 route status" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-11-24 start-time=04:42:54
/system scheduler add interval=2d name=export-download on-event=export-download policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-12-14 start-time=04:47:33
/system scheduler add disabled=yes interval=1h name="355 255 371 629 Route Status" on-event="355 255 371 629 Route Status" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-01-23 start-time=16:22:48
/system scheduler add interval=2w name=dynamic-data-rextended on-event=dynamic-data-rextended policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-09-30 start-time=02:58:29
/system scheduler add interval=30m name=Netwatch on-event=Netwatch policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-01-23 start-time=16:22:48
/system scheduler add disabled=yes interval=30m name=WG-iface-restart on-event=WG-iface-restart policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-03-13 start-time=06:41:55
/system scheduler add interval=5d name=IPlist on-event=IPlist policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-04-10 start-time=06:54:16
/system scheduler add disabled=yes name="Hassio Firmware Entity Publish" on-event="Hassio Firmware Entity Publish" policy=read,test start-time=startup
/system scheduler add disabled=yes interval=6h name="Hassio Firmware State Publish" on-event="Hassio Firmware State Publish" policy=read,write,policy,test start-time=startup
/system scheduler add disabled=yes name=HassioSensorHealthEntityPublish on-event=HassioSensorHealthEntityPublish policy=read,write,test start-time=startup
/system scheduler add disabled=yes interval=1h name=HassioSensorHealthStatePublish on-event=HassioSensorHealthStatePublish policy=read,write,test start-time=startup
/system scheduler add disabled=yes name=HassioSensorPoeEntityPublish on-event=HassioSensorPoeEntityPublish policy=read,write,test start-time=startup
/system scheduler add disabled=yes interval=1h name=HassioSensorPoeStatePublish on-event=HassioSensorPoeStatePublish policy=read,test start-time=startup
/system scheduler add interval=2w name=dhcpleasesftp on-event=dhcpleasesftp policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-12-14 start-time=04:47:33
/system scheduler add disabled=yes interval=30m name=WG-iface-restart-log-lasthandshake on-event=WG-iface-restart-log-lasthandshake policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-03-18 start-time=05:25:18
/system scheduler add interval=1d name=DynDNS on-event=DynDNS policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2022-10-18 start-time=02:00:00
/system scheduler add interval=1m name=UPSonline on-event=UPSonline policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-04-05 start-time=08:08:58
/system scheduler add interval=5m name=Data_to_Splunk on-event=Data_to_Splunk_using_Syslog policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-09-06 start-time=18:27:54
/system script add dont-require-permissions=no name=Netwatch-JRS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\r\
    \n:global prevstatus355;\r\
    \n:global updown355;\r\
    \n:global status355 [:ip route get value-name=active [:ip route find comment=\"355\"]]\r\
    \n\r\
    \n#:log info (\"status355 is \$status355\");\r\
    \n#:log info (\"prevstatus355 is \$prevstatus355\");\r\
    \n\r\
    \n:if ( \"\$status355\" = true ) do={:set updown355 UP} else= {:set updown355 DOWN}\r\
    \n\r\
    \n#:log info (\"updown355 is \$updown355\");\r\
    \n\r\
    \n:if ( \"\$status355\" != \"\$prevstatus355\" ) do={ \r\
    \n\r\
    \n#:log warn \"355 connectivity is now \\\"\$updown355\\\" \";\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"355 Connectivity now \\\"\$updown355\\\"\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \" SENT FROM 212hEX:  355 connectivity changed status from \\\"\$prevstatus355\\\" -> \\\"\$updown355\\\" \" )\r\
    \n\r\
    \n:set prevstatus355 \$status355\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:global prevstatus371;\r\
    \n:global updown371;\r\
    \n:global status371 [:ip route get value-name=active [:ip route find comment=\"371\"]]\r\
    \n\r\
    \n#:log info (\"status371 is \$status371\");\r\
    \n#:log info (\"prevstatus371 is \$prevstatus371\");\r\
    \n\r\
    \n:if ( \"\$status371\" = true ) do={:set updown371 UP} else= {:set updown371 DOWN}\r\
    \n\r\
    \n#:log info (\"updown371 is \$updown371\");\r\
    \n\r\
    \n:if ( \"\$status371\" != \"\$prevstatus371\" ) do={ \r\
    \n\r\
    \n#:log warn \"371 connectivity is now \\\"\$updown371\\\" \";\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"371 Connectivity now \\\"\$updown371\\\"\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \" SENT FROM 212hEX:  371 connectivity changed status from \\\"\$prevstatus371\\\" -> \\\"\$updown371\\\" \" )\r\
    \n\r\
    \n:set prevstatus371 \$status371\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n:global prevstatus255;\r\
    \n:global updown255;\r\
    \n:global status255 [:ip route get value-name=active [:ip route find comment=\"255\"]]\r\
    \n\r\
    \n#:log info (\"status255 is \$status255\");\r\
    \n#:log info (\"prevstatus255 is \$prevstatus255\");\r\
    \n\r\
    \n:if ( \"\$status255\" = true ) do={:set updown255 UP} else= {:set updown255 DOWN}\r\
    \n\r\
    \n#:log info (\"updown255 is \$updown255\");\r\
    \n\r\
    \n:if ( \"\$status255\" != \"\$prevstatus255\" ) do={ \r\
    \n\r\
    \n#:log warn \"255 connectivity is now \\\"\$updown255\\\" \";\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"255 Connectivity now \\\"\$updown255\\\"\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \" SENT FROM 212hEX:  255 connectivity changed status from \\\"\$prevstatus255\\\" -> \\\"\$updown255\\\" \" )\r\
    \n\r\
    \n:set prevstatus255 \$status255\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n:global prevstatus629;\r\
    \n:global updown629;\r\
    \n:global status629 [:ip route get value-name=active [:ip route find comment=\"629\"]]\r\
    \n\r\
    \n#:log info (\"status629 is \$status629\");\r\
    \n#:log info (\"prevstatus629 is \$prevstatus629\");\r\
    \n\r\
    \n:if ( \"\$status629\" = true ) do={:set updown629 UP} else= {:set updown629 DOWN}\r\
    \n\r\
    \n#:log info (\"updown629 is \$updown629\");\r\
    \n\r\
    \n:if ( \"\$status629\" != \"\$prevstatus629\" ) do={ \r\
    \n\r\
    \n#:log warn \"629 connectivity is now \\\"\$updown629\\\" \";\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"629 Connectivity now \\\"\$updown629\\\"\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \" SENT FROM 212hEX:  629 connectivity changed status from \\\"\$prevstatus629\\\" -> \\\"\$updown629\\\" \" )\r\
    \n\r\
    \n:set prevstatus629 \$status629\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n:global prevstatus76;\r\
    \n:global updown76;\r\
    \n:global status76 [:ip route get value-name=active [:ip route find comment=\"76\"]]\r\
    \n\r\
    \n#:log info (\"status76 is \$status76\");\r\
    \n#:log info (\"prevstatus76 is \$prevstatus76\");\r\
    \n\r\
    \n:if ( \"\$status76\" = true ) do={:set updown76 UP} else= {:set updown76 DOWN}\r\
    \n\r\
    \n#:log info (\"updown76 is \$updown76\");\r\
    \n\r\
    \n:if ( \"\$status76\" != \"\$prevstatus76\" ) do={ \r\
    \n\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"76 Connectivity now \\\"\$updown76\\\"\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \" SENT FROM 212hEX:  76 connectivity changed status from \\\"\$prevstatus76\\\" -> \\\"\$updown76\\\" \" )\r\
    \n\r\
    \n:set prevstatus76 \$status76\r\
    \n\r\
    \n}\r\
    \n\r\
    \n\r\
    \n}\r\
    \n"
/system script add dont-require-permissions=no name=GetIP owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/interface bridge host\r\
    \n:foreach item in=[find] do={\r\
    \n    :local iface  [get \$item interface]\r\
    \n    :local macadd [get \$item mac-address]\r\
    \n    :local idmac  [/ip arp find where mac-address=\$macadd]\r\
    \n    :if ([:len \$idmac] = 1) do={\r\
    \n        :local ifip [/ip arp get \$idmac address]\r\
    \n        :put   \"interface=\$iface mac=\$macadd ip=\$ifip\"\r\
    \n    }\r\
    \n}"
/system script add dont-require-permissions=no name="New route UP" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":global prevstatus355\r\
    \n{\r\
    \n    /ip route\r\
    \n    :local status355 [get [find where comment=\"355\"] active]\r\
    \n    :if (\$status355) do={:set status355 \"UP\"} else={:set status355 \"DOWN\"}\r\
    \n    :log info \"status355 is \$status355 and prevstatus355 is \$prevstatus355\"\r\
    \n    :if (\$status355 != \$prevstatus355) do={ \r\
    \n        :log warning \"355 connectivity is now \$status355\"\r\
    \n        /tool e-mail send to=XXXXX@XXXXX.com subject=\"355 Connectivity is now \$status355\" \\\r\
    \n                     body=\"\$[/system clock get date] \$[/system clock get time] 355 connectivity changed status \$prevstatus355 -> \$status355\"\r\
    \n        :set prevstatus355 \$status355\r\
    \n    }\r\
    \n}\r\
    \n"
/system script add dont-require-permissions=no name=export-download owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n\r\
    \n/system\r\
    \n:local identitydate \"\$[identity get name]_\$yyyy-\$MM-\$dd\"\r\
    \n/export show-sensitive file=\"\$identitydate\"\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n/file remove \"\$identitydate.rsc\"\r\
    \n\r\
    \n# /system logging set 0 topics=info\r\
    \n# /system logging add action=remote prefix=192.168.0.13 topics=info\r\
    \n\r\
    \n:log info (\"Uploaded rsc backup to 192.168.2.22 as \".\$identitydate)\r\
    \n\r\
    \n# /system logging set 0 topics=info,!script\r\
    \n# /system logging add action=remote prefix=192.168.0.13 topics=info,!script"
/system script add dont-require-permissions=yes name=WG-iface-restart owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-address~\"[a-z]\\\$\"] do={\r\
    \n  :local LastHandshake [/interface/wireguard/peers/get \$i last-handshake]\r\
    \n  :if (([:tostr \$LastHandshake] = \"\") or (\$LastHandshake > [:totime \"5m\"])) do={\r\
    \n   \r\
    \n     :log info \"WG-iface-restart script found WG peers with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint\"\r\
    \n\r\
    \n    /interface/wireguard/peers/set \$i endpoint-address=[/interface/wireguard/peers/get \$i endpoint-address]\r\
    \n\r\
    \n   :local endpoint [/interface/wireguard/peers/get \$i endpoint-address]\r\
    \n   :log info \"WG-iface-restart script found WG peer with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint:  \$endpoint\"\r\
    \n\r\
    \n  }\r\
    \n}\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=IPlist owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Export public IP and mail it\r\
    \n\r\
    \n/ip/address print file=\"212-IP-\$[\$nowdate]\"\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no src-path=\"212-IP-\$[\$nowdate].txt\" dst-path=\"/mikrotik-backups/212-IP-\$[\$nowdate].txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n/file remove \"212-IP-\$[\$nowdate].txt\""
/system script add dont-require-permissions=no name="DHCP to DNS" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# SPDX-License-Identifier: CC0-1.0\
    \n\r\
    \n\r\r\r\r\
    \n\r\
    \n\r\r:local domains [:toarray \"212.local\"]\
    \n\r\
    \n\r\r:local dnsttl \"100m\"\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:local magiccomment \"automatic-from-dhcp (magic comment)\"\
    \n\r\
    \n\r\r:local activehosts [:toarray \"\"]\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:foreach lease in [/ip dhcp-server lease find] do={\
    \n\r\
    \n\r\r  :local hostname [/ip dhcp-server lease get value-name=host-name \$lease]\
    \n\r\
    \n\r\r  :local hostaddr [/ip dhcp-server lease get value-name=address \$lease]\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r  :if ([:len \$hostname] > 0) do={\
    \n\r\
    \n\r\r    :foreach domain in \$domains do={\
    \n\r\
    \n\r\r      :local regdomain \"\$hostname.\$domain\"\
    \n\r\
    \n\r\r      :set activehosts (\$activehosts, \$regdomain)\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r      :if ([:len [/ip dns static find where name=\$regdomain]] = 0) do={\
    \n\r\
    \n\r\r        /ip dns static add name=\$regdomain address=\$hostaddr comment=\$magiccomment ttl=\$dnsttl\
    \n\r\
    \n\r\r      } else={\
    \n\r\
    \n\r\r        :if ([:len [/ip dns static find where name=\$regdomain comment=\$magiccomment]] = 1) do={\
    \n\r\
    \n\r\r          /ip dns static set address=\$hostaddr [/ip dns static find name=\$regdomain comment=\$magiccomment]\
    \n\r\
    \n\r\r        }\
    \n\r\
    \n\r\r      }\
    \n\r\
    \n\r\r    }\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:foreach dnsentry in [/ip dns static find where comment=\$magiccomment] do={\
    \n\r\
    \n\r\r  :local hostname [/ip dns static get value-name=name \$dnsentry]\
    \n\r\
    \n\r\r  :if ([:type [:find \$activehosts \$hostname]] = \"nil\") do={\
    \n\r\
    \n\r\r    /ip dns static remove \$dnsentry\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r"
/system script add dont-require-permissions=no name="Comment to DNS" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# SPDX-License-Identifier: CC0-1.0\
    \n\r\
    \n\r\r\r\r\
    \n\r\
    \n\r\
    \n\r\r:local dnsttl \"15m\"\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\r:local magiccomment \"automatic-from-comment (magic comment)\"\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\r  :local hostname [/ip dhcp-server lease get value-name=comment \$lease]\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r      } else={\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r        }\
    \n\r\
    \n\r\r      }\
    \n\r\
    \n\r\r    }\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\r  }\
    \n\r\
    \n\r\r}\
    \n\r\
    \n\r\r"
/system script add dont-require-permissions=no name="Get dhcp-client gatewat" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n:local dhcpclientGW  [/ip dhcp-client get [find interface=ether1] gateway]\r\
    \n\r\
    \n:log info \$dhcpclientGW\r\
    \n"
/system script add dont-require-permissions=no name=dynamic-data-rextended owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/system\r\
    \n:local identitydate \"\$[identity get name]_\$[clock get date]\"\r\
    \n:local stringexec   \"/system iden print; :put \\\"\\\\r\\\\n\\\"; /ip cloud pri; :put \\\"\\\\r\\\\n\\\";  /ip dhcp-server lease pri det; :put \\\"\\\\r\\\\n\\\"; /int bridge host pri det\"\r\
    \n\r\
    \n:if ([:len [/system package find where name=\"wifiwave2\"]] > 1) do={\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wifiwave2 reg pri det\"\r\
    \n} \r\
    \n\r\
    \n    :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wireless reg pri det\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n/file remove [find where name=tmpresults.txt]\r\
    \n:delay 1s\r\
    \n:execute \$stringexec file=tmpresults.txt\r\
    \n:delay 2s\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no address=192.168.2.22 port=21 user=mikrotik password=XXXXX \\\r\
    \n    src-path=tmpresults.txt dst-path=\"/mikrotik-backups/\$identitydate-dynamicdata.txt\"\r\
    \n\r\
    \n/file remove [find where name=tmpresults.txt]"
/system script add dont-require-permissions=no name="mqtt to HA" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/system script add dont-require-permissions=no name=mqttpublish owner=admin policy=\\\r\
    \n    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\"#\\\r\
    \n    \\_Required packages: iot\\r\\\r\
    \n    \\n\\r\\\r\
    \n    \\n################################ Configuration #########################\\\r\
    \n    #######\\r\\\r\
    \n    \\n# Name of an existing MQTT broker that should be used for publishing\\r\\\r\
    \n    \\n:local broker \\\"broker\\\"\\r\\\r\
    \n    \\n\\r\\\r\
    \n    \\n# MQTT topic where the message should be published\\r\\\r\
    \n    \\n:local topic \\\"my/test/topic\\\"\\r\\\r\
    \n    \\n\\r\\\r\
    \n    \\n#################################### System ############################\\\r\
    \n    #######\\r\\\r\
    \n    \\n:put (\\\"[*] Gathering system info...\\\")\\r\\\r\
    \n    \\n:local cpuLoad [/system resource get cpu-load]\\r\\\r\
    \n    \\n:local freeMemory [/system resource get free-memory]\\r\\\r\
    \n    \\n:local usedMemory ([/system resource get total-memory] - \\\$freeMemory)\\r\\\r\
    \n    \\n:local rosVersion [/system package get value-name=version \\\\\\r\\\r\
    \n    \\n\\A0 \\A0 [/system package find where name ~ \\\"^routeros\\\"]]\\r\\\r\
    \n    \\n:local model [/system routerboard get value-name=model]\\r\\\r\
    \n    \\n:local serialNumber [/system routerboard get value-name=serial-number]\\r\\\r\
    \n    \\n:local upTime [/system resource get uptime]\\r\\\r\
    \n    \\n\\r\\\r\
    \n    \\n#################################### MQTT ##############################\\\r\
    \n    #######\\r\\\r\
    \n    \\n:local message \\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\\"{\\\\\\\"model\\\\\\\":\\\\\\\"\\\$model\\\\\\\",\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"sn\\\\\\\":\\\\\\\"\\\$serialNumber\\\\\\\",\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"ros\\\\\\\":\\\\\\\"\\\$rosVersion\\\\\\\",\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"cpu\\\\\\\":\\\$cpuLoad,\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"umem\\\\\\\":\\\$usedMemory,\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"fmem\\\\\\\":\\\$freeMemory,\\\\\\r\\\r\
    \n    \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"uptime\\\\\\\":\\\\\\\"\\\$upTime\\\\\\\"}\\\"\\r\\\r\
    \n    \\n\\r\\\r\
    \n    \\n:log info \\\"\\\$message\\\";\\r\\\r\
    \n    \\n:put (\\\"[*] Total message size: \\\$[:len \\\$message] bytes\\\")\\r\\\r\
    \n    \\n:put (\\\"[*] Sending message to MQTT broker...\\\")\\r\\\r\
    \n    \\n/iot mqtt publish broker=\\\$broker topic=\\\$topic message=\\\$message\\r\\\r\
    \n    \\n:put (\\\"[*] Done\\\")\""
/system script add dont-require-permissions=no name=mqttpublish owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Required packages: iot\r\
    \n\r\
    \n################################ Configuration ################################\r\
    \n# Name of an existing MQTT broker that should be used for publishing\r\
    \n:local broker \"broker\"\r\
    \n\r\
    \n# MQTT topic where the message should be published\r\
    \n:local topic \"my/test/topic\"\r\
    \n\r\
    \n#################################### System ###################################\r\
    \n:put (\"[*] Gathering system info...\")\r\
    \n:local cpuLoad [/system resource get cpu-load]\r\
    \n:local freeMemory [/system resource get free-memory]\r\
    \n:local usedMemory ([/system resource get total-memory] - \$freeMemory)\r\
    \n:local rosVersion [/system package get value-name=version \\\r\
    \n\A0 \A0 [/system package find where name ~ \"^routeros\"]]\r\
    \n:local model [/system routerboard get value-name=model]\r\
    \n:local serialNumber [/system routerboard get value-name=serial-number]\r\
    \n:local upTime [/system resource get uptime]\r\
    \n\r\
    \n#################################### MQTT #####################################\r\
    \n:local message \\\r\
    \n\A0 \A0 \"{\\\"model\\\":\\\"\$model\\\",\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"sn\\\":\\\"\$serialNumber\\\",\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"ros\\\":\\\"\$rosVersion\\\",\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"cpu\\\":\$cpuLoad,\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"umem\\\":\$usedMemory,\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"fmem\\\":\$freeMemory,\\\r\
    \n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"uptime\\\":\\\"\$upTime\\\"}\"\r\
    \n\r\
    \n:log info \"\$message\";\r\
    \n:put (\"[*] Total message size: \$[:len \$message] bytes\")\r\
    \n:put (\"[*] Sending message to MQTT broker...\")\r\
    \n/iot mqtt publish broker=\$broker topic=\$topic message=\$message\r\
    \n:put (\"[*] Done\")"
/system script add dont-require-permissions=no name="DHCP to DNS -- NEW" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# SPDX-License-Identifier: CC0-1.0\r\
    \n\r\
    \n:local domains [:toarray \"212.local\"]\r\
    \n:local dnsttl \"100m\"\r\
    \n:local magiccomment \"automatic-from-dhcp (magic comment)\"\r\
    \n:local activehosts [:toarray \"\"]\r\
    \n\r\
    \n:foreach lease in [/ip dhcp-server lease find] do={\r\
    \n  :local hostname [/ip dhcp-server lease get value-name=host-name \$lease]\r\
    \n  :local hostaddr [/ip dhcp-server lease get value-name=address \$lease]\r\
    \n  :local macaddr [/ip dhcp-server lease get value-name=mac-address \$lease]\r\
    \n\r\
    \n  :if ([:len \$hostname] > 0) do={\r\
    \n\r\
    \n    :foreach domain in \$domains do={\r\
    \n\r\
    \n      :local regdomain \"\$hostname.\$domain\"\r\
    \n      :set activehosts (\$activehosts, \$regdomain)\r\
    \n\r\
    \n      :if ([:len [/ip dns static find where name=\$regdomain]] = 0) do={\r\
    \n        /ip dns static add name=\$regdomain address=\$hostaddr comment=\$magiccomment ttl=\$dnsttl\r\
    \n      } else={\r\
    \n        :if ([/ip dns static find where name=\$regdomain] = \$hostname) | ([/ip dhcp-server lease find where address=\$hostaddr] = \$macaddr) do=(\r\
    \n\t\t  :set regdomain=(\"\$hostname\", \"-1\")       \r\
    \n          :/ip dns static add name=\$regdomain address=\$hostaddr comment=\$magiccomment ttl=\$dnsttl\r\
    \n        }  \r\
    \n          else={\r\
    \n          }\r\
    \n\r\
    \n\r\
    \n        :if ([:len [/ip dns static find where name=\$regdomain comment=\$magiccomment]] = 1) do={\r\
    \n          /ip dns static set address=\$hostaddr [/ip dns static find name=\$regdomain comment=\$magiccomment]\r\
    \n        \r\
    \n      }\r\
    \n    }\r\
    \n  }\r\
    \n\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=rogue-dhcp owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":log warning message=\"Rogue DHCP server detected!\""
/system script add dont-require-permissions=no name=HassioLib_DeviceString owner=admin policy=read source="# Use\r\
    \n# local DeviceString [parse [system/script/get \"HassioLib_DeviceString\" source]]\r\
    \n# \$DeviceString\r\
    \n#\r\
    \nlocal ID\r\
    \nlocal connections\r\
    \nlocal hwversion\r\
    \nlocal LowercaseHex [parse [system/script/get \"HassioLib_LowercaseHex\" source]]\r\
    \n# Get serial\r\
    \nif ([/system/resource/get board-name] != \"CHR\") do={\r\
    \n    set ID (\"\\\"\".[/system/routerboard get serial-number].\"\\\"\");#ID\r\
    \n    set \$hwversion [[:parse \"[system/routerboard/get revision]\"]]\r\
    \n    if ([len \$hwversion] >0) do={\r\
    \n        set \$hwversion (\"\\\"hw_version\\\":\\\"\".\$hwversion.\"\\\",\")\r\
    \n    }\r\
    \n} else={\r\
    \n    set ID (\"\\\"\".[system/license/get system-id ].\"\\\"\")\r\
    \n}\r\
    \n\r\
    \nlocal Name [/system/identity/get name];       #Name\r\
    \nlocal Model [system/resource/get board-name]; #Mode\r\
    \nlocal CSW   [/system/resource/get version ];  #SW\r\
    \nlocal Manu [/system/resource/get platform];   #Manufacturer\r\
    \n\r\
    \n\r\
    \n# Get Ethernet MAC addresses\r\
    \nforeach iface in=[interface/ethernet/find ] do={\r\
    \n    set \$connections (\$connections.\"[\\\"mac\\\",\\\"\".\\\r\
    \n        [\$LowercaseHex input=[/interface/ethernet/get \$iface mac-address]].\\\r\
    \n        \"\\\"],\")\r\
    \n}\r\
    \n\r\
    \n# Get Wi-Fi MAC addresses\r\
    \nif ([len [system/package/find name=\"wifiwave2\"]]  =0 ) do={\r\
    \n    local Action [parse \"local a [interface/wireless/get \\\$1 mac-address];return \\\$a\"]\r\
    \n    foreach iface in=[[parse \"/interface/wireless/ find interface-type!=\\\"virtual\\\"\"]] do={\r\
    \n            [\$LowercaseHex input=[\$Action \$iface]].\\\r\
    \n            \"\\\"],\")\r\
    \n    }\r\
    \n}\\\r\
    \n# Get Wi-Fi Wave2 MAC Addresses\r\
    \nelse={\r\
    \n    local Action [parse \"local a [/interface/wifiwave2/radio/get \\\$1 radio-mac];return \\\$a\"]\r\
    \n    foreach iface in=[[parse \"/interface/wifiwave2/radio/find\"]] do={\r\
    \n            \"\\\"],\")\r\
    \n    }\r\
    \n}\r\
    \nset \$connections [pick \$connections -1 ([len \$connections]-1)]; #Remove trailing comma\r\
    \n\r\
    \n# Find a reasonable link to WebFig if enabled.\r\
    \nlocal urldomain\r\
    \nlocal ipaddress\r\
    \n\r\
    \nforeach bridge in=[/interface/bridge/find] do={\r\
    \n    foreach AddressIndex in=[ip/address/find where interface=[/interface/bridge/get \$bridge name]] do={\r\
    \n        set ipaddress [/ip/address/get \$AddressIndex address]\r\
    \n        set \$ipaddress [:pick \$ipaddress 0 [:find \$ipaddress \"/\"]]\r\
    \n       foreach UrlIndex in=[/ip/dns/static/ find address=\$ipaddress name] do={\r\
    \n            set \$urldomain [/ip/dns/static/ get \$UrlIndex name  ]\r\
    \n        }\r\
    \n    }\r\
    \n}\r\
    \nif ([len \$ipaddress]=0) do={\r\
    \n    foreach addr in=[/ip/address/find] do={\r\
    \n        local TempAddress [/ip/address/get \$addr address]\r\
    \n        set \$TempAddress [:pick \$TempAddress 0 [:find \$TempAddress \"/\"]]\r\
    \n        foreach UrlIndex in=[/ip/dns/static/find address=\$TempAddress] do={\r\
    \n            local TempUrlDomain [ip/dns/static/get \$UrlIndex name]\r\
    \n            if ([len \$TempUrlDomain]>0) do={set \$urldomain \$TempUrlDomain}\r\
    \n        }\r\
    \n    }\r\
    \n}\r\
    \nif ([len \$urldomain]>0) do={set \$ipaddress \$urldomain}\r\
    \n\r\
    \nlocal url\r\
    \nif ([len \$ipaddress] >0) do={\r\
    \n    :if (! [/ip/service/get www-ssl disabled ]) \\\r\
    \n        do={:set \$url \",\\\"cu\\\":\\\"https://\$ipaddress/\\\"\"} \\\r\
    \n    else={if (! [/ip/service/get www disabled]) \\\r\
    \n        do={:set \$url \",\\\"cu\\\":\\\"http://\$ipaddress/\\\"\"}}\r\
    \n}\r\
    \n        #-------------------------------------------------------\r\
    \n        #Build device string\r\
    \n        local dev \"\\\"dev\\\":{\\\r\
    \n            \\\"ids\\\":[\$ID],\\\r\
    \n            \\\"connections\\\":[\$connections],\\\r\
    \n            \\\"name\\\":\\\"\$Name\\\",\\\r\
    \n            \\\"mdl\\\":\\\"\$Model\\\",\$hwversion\\\r\
    \n            \\\"sw\\\":\\\"\$CSW\\\",\\\r\
    \n            \\\"mf\\\":\\\"\$Manu\\\"\$url}\"\r\
    \n\r\
    \n\r\
    \nreturn \$dev"
/system script add dont-require-permissions=no name=HassioLib_JsonEscape owner=admin policy=read source="# local JsonEscape [parse [system/script/get \"HassioLib_JsonEscape\" source]]\
    \n# \$JsonEscape input=\$a4\
    \n#\
    \n#global JsonEscape do= {\
    \n    #:global SearchReplace\
    \n    local SearchReplace [parse [system/script/get \"HassioLib_SearchReplace\" source]]\
    \n    :local escchars   {\"\\\\\";\"\\\"\";\"/\";\"\\08\";\"\\0C\";\"\\0A\";\"\\0D\";\"\\08\"};\
    \n    :local escReplace {\"\\\\\\\\\";\"\\\\\\\"\";\"\\\\/\";\"\\\\b\";\"\\\\f\";\"\\\\n\";\"\\\\r\";\"\\\\t\"}\
    \n    foreach k,escchar in=\$escchars do={\
    \n        set \$input [\$SearchReplace input=\$input search=\$escchar replace=(\$escReplace->(\$k))]\
    \n    }\
    \n    return \$input\
    \n\
    \n#}"
/system script add dont-require-permissions=no name=HassioLib_JsonPick owner=admin policy=read source="# Use\r\
    \n# local JsonPick [parse [system/script/get \"HassioLib_JsonPick\" source]]\r\
    \n# \$JsonPick input=\$a2 len=255\r\
    \n#\r\
    \n#global JsonPick do= {\r\
    \n    set \$input [pick \$input -1 \$len]\r\
    \n    local length [len \$input]\r\
    \n    if (([pick \$input (\$length-1)] = \"\\\\\") && ([pick \$input (\$length-2)] != \"\\\\\")) do= {\r\
    \n        set \$input [:pick (\$input) -1 (\$length-1)]\r\
    \n    }\r\
    \n    return \$input\r\
    \n#}"
/system script add dont-require-permissions=no name=HassioLib_LowercaseHex owner=admin policy=read source="# Use\r\
    \n# local LowercaseHex [parse [system/script/get \"HassioLib_LowercaseHex\" source]]\r\
    \n# \$LowercaseHex input=\$a4\r\
    \n#\r\
    \n#global LowercaseHex do= {\r\
    \n    #:global SearchReplace\r\
    \n    local SearchReplace [parse [system/script/get \"HassioLib_SearchReplace\" source]]\r\
    \n    :local escchars {\"A\";\"B\";\"C\";\"D\";\"E\";\"F\"}\r\
    \n    :local escReplace {\"a\";\"b\";\"c\";\"d\";\"e\";\"f\"}\r\
    \n    foreach k,escchar in=\$escchars do={\r\
    \n        set \$input [\$SearchReplace input=\$input search=\$escchar replace=(\$escReplace->(\$k))]\r\
    \n    }\r\
    \n\r\
    \n#}"
/system script add dont-require-permissions=no name=HassioLib_SearchReplace owner=admin policy=read source="# Use\r\
    \n# local SearchReplace [parse [system/script/get \"HassioLib_SearchReplace\" source]]\r\
    \n# \$SearchReplace input=\"abc\" search=\"a\" replace=\"b\"\r\
    \n#\r\
    \n#global SearchReplace do= {\r\
    \n    :local out \"\"\r\
    \n    :local index 0\r\
    \n    :local length [:len \$input]\r\
    \n    :local findex\r\
    \n\r\
    \n    set \$findex [find \$input \$search (\$index-1) ]\r\
    \n    while ([len \$findex] != \"0\") do={\r\
    \n        set \$out (\$out.[pick \$input \$index \$findex ].\$replace)\r\
    \n        set \$index (\$findex+[len \$search])\r\
    \n    }\r\
    \n    set \$out (\$out.[pick \$input (\$index) \$length ])\r\
    \n    :return \$out\r\
    \n#}\r\
    \n"
/system script add dont-require-permissions=no name="Hassio Firmware Entity Publish" owner=admin policy=read,test source="if ([len [system/package/find name=\"iot\"]]=0) do={ ; # If IOT packages is  not installed\r\
    \n    log/error message=\"HassioMQTT: IOT package not installed.\"\r\
    \n} else={\r\
    \n    if ([len [iot/mqtt/brokers/find name=\"Home Assistant\"]]=0) do={ ;# If Home assistant broker does not exist\r\
    \n        log/error message=\"HassioMQTT: Broker does not exist.\"\r\
    \n    } else={\r\
    \n        while (![/iot/mqtt/brokers/get [/iot/mqtt/brokers/find name=\"Home Assistant\"] connected ]) do={ ;# If Home assistant broker is not connected\r\
    \n            log/info message=\"HassioMQTT: Broker not connected reattempting connection...\"\r\
    \n            delay 1m; # Wait and attempt reconnect\r\
    \n            iot/mqtt/connect broker=\"Home Assistant\"\r\
    \n        }\r\
    \n\r\
    \n\r\
    \n        local discoverypath \"homeassistant/\"\r\
    \n        local domainpath \"update/\"\r\
    \n\r\
    \n        #Get variables to build device string\r\
    \n\r\
    \n        local ID\r\
    \n        if ([/system/resource/get board-name] != \"CHR\") do={\r\
    \n        set ID [/system/routerboard get serial-number];#ID\r\
    \n        } else={\r\
    \n        set ID [system/license/get system-id ]\r\
    \n        }\r\
    \n        local DeviceString [parse [system/script/get \"HassioLib_DeviceString\" source]]\r\
    \n        local dev [\$DeviceString]\r\
    \n        local buildconfig do= {\r\
    \n\r\
    \n            #build config for Hassio\r\
    \n            local config \"{\\\"~\\\":\\\"\$discoverypath\$domainpath\$ID/\$name\\\",\\\r\
    \n                \\\"name\\\":\\\"\$name\\\",\\\r\
    \n                \\\"stat_t\\\":\\\"~/state\\\",\\\r\
    \n                \\\"uniq_id\\\":\\\"\$ID_\$name\\\",\\\r\
    \n                \\\"obj_id\\\":\\\"\$ID_\$name\\\",\\\r\
    \n                \$dev\\\r\
    \n            }\"\r\
    \n            /iot/mqtt/publish broker=\"Home Assistant\" message=\$config topic=\"\$discoverypath\$domainpath\$ID/\$name/config\" retain=yes              \r\
    \n        }\r\
    \n        #Handle routerboard firmware for non CHR\r\
    \n            \$buildconfig name=\"RouterBOARD\" ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\r\
    \n        }\r\
    \n\r\
    \n        #Handle RouterOS\r\
    \n        \$buildconfig name=\"RouterOS\" ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\r\
    \n\r\
    \n        #Handle LTE interfaces\r\
    \n        :foreach iface in=[/interface/lte/ find] do={\r\
    \n        local ifacename [/interface/lte get \$iface name]\r\
    \n\r\
    \n        #Get manufacturer and model for LTE interface\r\
    \n        local lte [ [/interface/lte/monitor [/interface/lte get \$iface name] once as-value] manufacturer]\r\
    \n            if (\$lte->\"manufacturer\"=\"\\\"MikroTik\\\"\") do={\r\
    \n                {\r\
    \n                #build config for LTE\r\
    \n                local modemname [:pick (\$lte->\"model\")\\\r\
    \n                    ([:find (\$lte->\"model\") \"\\\"\" -1] +1)\\\r\
    \n                    [:find (\$lte->\"model\") \"\\\"\" [:find (\$lte->\"model\") \"\\\"\" -1]]]\r\
    \n                \$buildconfig name=\$modemname ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\r\
    \n                }\r\
    \n            }\r\
    \n        }\r\
    \n    }\r\
    \n}"
/system script add dont-require-permissions=no name="Hassio Firmware State Publish" owner=admin policy=read,write,policy,test source="if ([len [system/package/find name=\"iot\"]]=0) do={ ; # If IOT packages is  not installed\r\
    \n} else={\r\
    \n    } else={\r\
    \n        local Ctr 0\r\
    \n        while ((![/iot/mqtt/brokers/get [/iot/mqtt/brokers/find name=\"Home Assistant\"] connected ])&&(Ctr<12)) do={ ;# If Home assistant broker is not connected\r\
    \n            set \$Ctr (\$Ctr+1)\r\
    \n        }\r\
    \n        :global HassioReleaseNote\r\
    \n        #ID\r\
    \n        local ID\r\
    \n        } else={\r\
    \n        }\r\
    \n\r\
    \n        local poststate do= {\r\
    \n            if ((typeof \$url)!=nil) do={\r\
    \n            set \$url  \",\\\"release_url\\\":\\\"\$url\\\"\"\r\
    \n            }\r\
    \n\r\
    \n            if ((typeof \$note)!=nil) do={\r\
    \n            set \$note \",\\\"release_summary\\\":\\\"\$note\\\"\"\r\
    \n            }\r\
    \n\r\
    \n            local state \"{\\\"installed_version\\\":\\\"\$cur\\\",\\\r\
    \n                \\\"latest_version\\\":\\\"\$new\\\"\$url\$note}\"\r\
    \n            /iot/mqtt/publish broker=\"Home Assistant\" message=\$state topic=\"\$discoverypath\$domainpath\$ID/\$name/state\" retain=yes\r\
    \n        }\r\
    \n            #Get routerboard firmware\r\
    \n            local Act [parse \"/system/routerboard/get current-firmware\"]\r\
    \n            local cur [\$Act]\r\
    \n            local Act [parse \"/system/routerboard/get upgrade-firmware\"]\r\
    \n            local new [\$Act]\r\
    \n            #post Routerboard firmware\r\
    \n            \$poststate name=\"RouterBOARD\" cur=\$cur new=\$new ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath\r\
    \n        }\r\
    \n\r\
    \n        #Get system software\r\
    \n        local versions [/system/package/update/check-for-updates as-value ]\r\
    \n\r\
    \n        local cur (\$versions->\"installed-version\")\r\
    \n        local new (\$versions->\"latest-version\")\r\
    \n\r\
    \n        #Get release note:\r\
    \n        if ((\$HassioReleaseNote->\"version\")!=new) do={\r\
    \n            #:global HassioReleaseNote\r\
    \n\r\
    \n            :set (\$HassioReleaseNote->\"note\") ([/tool/fetch \"http://upgrade.mikrotik.com/routeros/\$new/CHANGELOG\" output=user as-value]->\"data\")\r\
    \n            :set (\$HassioReleaseNote->\"note\") [:pick (\$HassioReleaseNote->\"note\") -1 255]\r\
    \n\r\
    \n            #Text must be escaped before posting as JSON!\r\
    \n            local JsonEscape [parse [system/script/get \"HassioLib_JsonEscape\" source]]\r\
    \n            set (\$HassioReleaseNote->\"note\") [\$JsonEscape input=(\$HassioReleaseNote->\"note\")]\r\
    \n\r\
    \n            local JsonPick [parse [system/script/get \"HassioLib_JsonPick\" source]]\r\
    \n            set (\$HassioReleaseNote->\"note\") [\$JsonPick input=(\$HassioReleaseNote->\"note\") len=255]\r\
    \n            :set (\$HassioReleaseNote->\"version\") \$new\r\
    \n            /log/debug message=\"HassioMQTT: Release note fetched.\"\r\
    \n        } else={/log/debug message=\"HassioMQTT: Release note already cached, not fetched.\"}\r\
    \n\r\
    \n        local urls {development=\"https://mikrotik.com/download/changelogs/development-release-tree\";\\\r\
    \n            long-term=\"https://mikrotik.com/download/changelogs/long-term-release-tree\";\\\r\
    \n            stable=\"https://mikrotik.com/download/changelogs/stable-release-tree\";\\\r\
    \n            testing=\"https://mikrotik.com/download/changelogs/testing-release-tree\"}\r\
    \n        set urls (\$urls->[system/package/update/get channel ])\r\
    \n\r\
    \n        \$poststate name=\"RouterOS\" cur=\$cur new=\$new url=\$urls note=(\$HassioReleaseNote->\"note\") ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath\r\
    \n\r\
    \n\r\
    \n                {\r\
    \n\r\
    \n                #Get firmware version for LTE interface\r\
    \n                local Firmware [/interface/lte firmware-upgrade [/interface/lte get \$iface name] once as-value ]\r\
    \n                local cur (\$Firmware->\"installed\")\r\
    \n                local new (\$Firmware->\"latest\")\r\
    \n\r\
    \n                \$poststate name=\$modemname cur=\$cur new=\$new ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath\r\
    \n                }\r\
    \n            }\r\
    \n        }\r\
    \n    }\r\
    \n}"
/system script add dont-require-permissions=no name=HassioSensorHealthEntityPublish owner=admin policy=read,test source="if ([len [system/package/find name=\"iot\"]]=0) do={ ; # If IOT packages is  not installed\r\
    \n} else={\r\
    \n    } else={\r\
    \n        }\r\
    \n\r\
    \n        local domainpath \"sensor/\"\r\
    \n\r\
    \n\r\
    \n        local ID [/system/routerboard get serial-number];#ID\r\
    \n\r\
    \n            local jsonname (\"x\".[\$SearchReplace input=\$name search=\"-\" replace=\"_\"])\r\
    \n\r\
    \n            local config \"{\\\"name\\\":\\\"\$name\\\",\\\r\
    \n                \\\"stat_t\\\":\\\"\$discoverypath\$domainpath\$ID/state\\\",\\\r\
    \n                \\\"suggested_display_precision\\\": 1,\\\r\
    \n                \\\"unit_of_measurement\\\": \\\"\$unit\\\",\\\r\
    \n                \\\"value_template\\\": \\\"{{ value_json.\$jsonname }}\\\",\\\r\
    \n                \\\"expire_after\\\":70,\\\r\
    \n                \$dev\\\r\
    \n            }\"\r\
    \n        }\r\
    \n        foreach sensor in=[/system/health/find] do={\r\
    \n            local name [/system/health/get \$sensor name];#name\r\
    \n            local unit [/system/health/get \$sensor type];#unit\r\
    \n            if (\$unit=\"C\") do={set \$unit \"\\C2\\B0\\43\"}\r\
    \n            \$buildconfig name=\$name unit=\$unit ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\r\
    \n        }\r\
    \n    }\r\
    \n}"
/system script add dont-require-permissions=no name=HassioSensorHealthStatePublish owner=admin policy=read,write,test source="if ([len [system/package/find name=\"iot\"]]=0) do={ ; # If IOT packages is  not installed\r\
    \n} else={\r\
    \n    } else={\r\
    \n\r\
    \n        #ID\r\
    \n        local ID [/system/routerboard get serial-number] \r\
    \n\r\
    \n        local string \"{\"\r\
    \n            set \$string ((\$string).(\"\\\"\").\\\r\
    \n                (\"x\").([\$SearchReplace input=[/system/health/get \$sensor name] search=\"-\" replace=\"_\"]).(\"\\\":\").\\\r\
    \n                ([/system/health/get \$sensor value]).(\",\"))\r\
    \n        }\r\
    \n        set \$string ([pick \$string -1 ([len \$string ]-1)].\"}\")\r\
    \n        \r\
    \n        /iot/mqtt/publish broker=\"Home Assistant\" message=\$string topic=\"\$discoverypath\$domainpath\$ID/state\" retain=no   \r\
    \n    }\r\
    \n}"
/system script add dont-require-permissions=no name=HassioSensorPoeEntityPublish owner=admin policy=read,test source="if ([len [system/package/find name=\"iot\"]]=0) do={ ; # If IOT packages is  not installed\
    \n} else={\
    \n    } else={\
    \n        }\
    \n\
    \n\
    \n\
    \n\
    \n            local config (\"{\\\"name\\\":\\\"\$name\".\" POE\".\"\\\",\\\
    \n                \\\"stat_t\\\":\\\"\$discoverypath\$domainpath\$ID/state\$NamePostfix\\\",\\\
    \n                \\\"uniq_id\\\":\\\"\$ID_\$name\$NamePostfix\\\",\\\
    \n                \\\"obj_id\\\":\\\"\$ID_\$name\$NamePostfix\\\",\\\
    \n                \\\"value_template\\\": \\\"{{ value_json.\$jsonname | is_defined}}\\\",\\\
    \n                \$dev\\\
    \n            }\")\
    \n            /iot/mqtt/publish broker=\"Home Assistant\" message=\$config topic=(\"\$discoverypath\$domainpath\$ID/\$name\$NamePostfix/config\") retain=yes        \
    \n        }\
    \n        foreach sensor in=[/interface/ethernet/poe/find] do={\
    \n            local name [/interface/ethernet/poe/get \$sensor name];#name\
    \n            \$buildconfig name=(\$name) unit=W NamePostfix=\"_poe\" ID=\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\
    \n        }\
    \n    }\
    \n}"
/system script add dont-require-permissions=no name=HassioSensorPoeStatePublish owner=admin policy=read,test source="local discoverypath \"homeassistant/\"\
    \nlocal domainpath \"sensor/\"\
    \nlocal ID [/system/routerboard get serial-number] \
    \n\
    \nlocal Out \"{\"\
    \n\
    \nforeach iface in=[/interface/ethernet/poe/ find] do={\
    \n    local InterfaceName [/interface/ethernet/poe/get \$iface name]\
    \n    local InterfaceValue [interface/ethernet/poe/monitor \$iface once as-value ]\
    \n    if ([:len (\$InterfaceValue->\"poe-out-current\")]=0) do={set (\$InterfaceValue->\"poe-out-current\") 0}\
    \n    set \$Out (\$Out.\"\\\"x\$InterfaceName\\\":\".\\\
    \n    [([:tonum [(\$InterfaceValue->\"poe-out-current\")]]/10) ].\\\
    \n    \".\".\\\
    \n    ([:tonum [(\$InterfaceValue->\"poe-out-current\")]]%10).\\\
    \n    \",\")\
    \n}\
    \nset \$Out ([pick \$Out -1 ([len \$Out]-1)].\"}\")\
    \n/iot/mqtt/publish broker=\"Home Assistant\" message=\$Out topic=\"\$discoverypath\$domainpath\$ID/state_poe\" retain=no"
/system script add dont-require-permissions=no name=DHCP-LEASE-TEST2 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/system\r\
    \n\r\
    \n\r\
    \n:foreach i in=[/ip dhcp-server lease find] do={\r\
    \n:put ([get \$i comment].\",\".[get \$i address].\",\".[get \$i mac-address].\",\".[get \$i host-name])\r\
    \n\r\
    \nfile=\"test1.txt\"\r\
    \n}"
/system script add dont-require-permissions=no name=dhcpleasesftp owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n/file remove [find where name=temp3.txt]\r\
    \n\r\
    \n/system\r\
    \n\r\
    \n:local identitydate \"\$[identity get name]\"\r\
    \n\r\
    \n:local stringexec \"/ip dhcp-server lease; :foreach i in=[find] do={ :put ([get \\\$i address].\\\",\\\".[get \\\$i comment].\\\",\\\",[get \\\$i mac-address].\\\",\\\".[get \\\$i host-name]  ) }\"\r\
    \n\r\
    \n\r\
    \n:execute \$stringexec file=temp3\r\
    \n\r\
    \n:delay 60\r\
    \n\r\
    \n/tool fetch address=192.168.2.22 port=21 user=mikrotik password=XXXXX src-path=temp3.txt mode=ftp dst-path=\"/mikrotik-backups/\$identitydate-leases.txt\" upload=yes ascii=no\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=script1 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n/file remove [find where name=temp2.txt]\r\
    \n\r\
    \n/system\r\
    \n\r\
    \n\r\
    \n:local stringexec \"/ip dhcp-server lease; :foreach i in=[find] do={ :put ([get \\\$i address].\\\",\\\".[get \\\$i comment].\\\",\\\",[get \\\$i mac-address].\\\",\\\".[get\r\
    \n \\\$i host-name]  ) }\"\r\
    \n\r\
    \n\r\
    \n:execute \$stringexec file=temp2.txt\r\
    \n\r\
    \n/tool fetch upload=yes mode=ftp ascii=no address=192.168.2.22 port=21 user=mikrotik password=XXXXX src-path=\"temp2.txt\" dst-path=\"/mikrotik-backups/\$identitydate-leases.txt\"\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n"
/system script add dont-require-permissions=yes name=WG-iface-restart-log-lasthandshake owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-address~\"[a-z]\\\$\"] do={\r\
    \n\r\
    \n#  :if (([:tostr \$LastHandshake] = \"\") or (\$LastHandshake > [:totime \"2m\"])) do={\r\
    \n\r\
    \n  :if ((\$LastHandshake > [:totime \"2m\"])) do={\r\
    \n\r\
    \n#  :local lasthandshaketime [:totime]\r\
    \n\r\
    \n  :log info \"WG-iface-restart-log-lasthandshake script found WG peer with last handshake greater than 2 minutes: \$endpoint \$LastHandshake\"\r\
    \n    \r\
    \n#    /interface/wireguard/peers/set \$i endpoint-address=[/interface/wireguard/peers/get \$i endpoint-address]\r\
    \n\r\
    \n  }\r\
    \n}\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=DynDNS owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n/system\r\
    \n:local cdate [clock get date] \r\
    \n:local yyyy  [:pick \$cdate 0  4]\r\
    \n:local MM    [:pick \$cdate 5  7]\r\
    \n:local dd    [:pick \$cdate 8 10]\r\
    \n#/export show-sensitive file=\"\$identitydate\"\r\
    \n\r\
    \n# Export public IP and mail it\r\
    \n\r\
    \n#/ip/address print file=\"\$identitydate-IP\"\r\
    \n\r\
    \n#/tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-IP.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n#/file remove \"\$identitydate-IP.txt\"\r\
    \n\r\
    \n# Set needed variables\r\
    \n\t:local username \"XXXXXXXXXX\"\r\
    \n\t:local clientkey \"XXXXX"\r\
    \n\t:local hostname \"XXXXX.dyndns.org\"\r\
    \n\r\
    \n\t:global dyndnsForce\r\
    \n\t:global previousIP\r\
    \n\r\
    \n# get the current IP address from the internet (in case of double-nat)\r\
    \n\t/tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" dst-path=\"/dyndns.checkip.html\"\r\
    \n\t:delay 1\r\
    \n\t:local result [/file get dyndns.checkip.html contents]\r\
    \n\r\
    \n# parse the current IP result\r\
    \n\t:local resultLen [:len \$result]\r\
    \n\t:local startLoc [:find \$result \": \" -1]\r\
    \n\t:set startLoc (\$startLoc + 2)\r\
    \n\t:local endLoc [:find \$result \"</body>\" -1]\r\
    \n\t:local currentIP [:pick \$result \$startLoc \$endLoc]\r\
    \n\t:log info \"UpdateDynDNS: currentIP = \$currentIP\"\r\
    \n\r\
    \n# Remove the # on next line to force an update every single time - useful for debugging,\r\
    \n# but you could end up getting blacklisted by DynDNS!\r\
    \n\r\
    \n#:set dyndnsForce true\r\
    \n\r\
    \n# Determine if dyndns update is needed\r\
    \n# more dyndns updater request details https://help.dyn.com/remote-access-api/perform-update/\r\
    \n\t:log info \"UpdateDynDNS: previousIP = \$previousIP\"\r\
    \n\t:if (\$dyndnsForce = true) do={ :log warning \"UpdateDynDNS: Forced update on\" }\r\
    \n\r\
    \n\t:if ((\$currentIP != \$previousIP) || (\$dyndnsForce = true)) do={\r\
    \n\t\t:set dyndnsForce false\r\
    \n\t\t:set previousIP \$currentIP\r\
    \n\r\
    \n\t\t/tool fetch mode=https \\\r\
    \n\t\turl=\"https://\$username:\$clientkey@members.dyndns.org/v3/update\?hostname=\$hostname&myip=\$currentIP\" \\ \r\
    \n\t\tdst-path=\"/dyndns.txt\"\r\
    \n\r\
    \n\t\t:delay 1\r\
    \n\t\t:local result [/file get dyndns.txt contents]\r\
    \n\t\t:log info (\"UpdateDynDNS: Dyndns update needed\")\r\
    \n\t\t:log info (\"UpdateDynDNS: Dyndns Update Result: \".\$result)\r\
    \n\t\t:put (\"Dyndns Update Result: \".\$result)\r\
    \n\r\
    \n                                           /ip/address print file=\"\$identitydate-IP\"\r\
    \n\r\
    \n                                          /tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-IP.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=192.168.2.22 port=21 user=mikrotik password=XXXXX\r\
    \n\r\
    \n                                          /file remove \"\$identitydate-IP.txt\"\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t} else={\r\
    \n\t\t:log info (\"UpdateDynDNS: No dyndns update needed\")\r\
    \n\t}\r\
    \n\r\
    \n"
/system script add dont-require-permissions=no name=UPSonline owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n\r\
    \n\r\
    \n:set curonline true\r\
    \n\r\
    \n/system up monitor 0 once\r\
    \n\r\
    \n:set curonline \$\"on-line\"\r\
    \n\r\
    \n:if (\$curonline=false) do={\r\
    \n :log info \"POWER FAIL.  POWER TO UPS IS OFF\"\r\
    \n}\r\
    \n\r\
    \n"
/system script add dont-require-permissions=yes name=Netwatch owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="####################################\r\
    \n# Netwatch script\r\
    \n#\r\
    \n# Used as both up and down script\r\
    \n# Created Jotne 2021 v1.5\r\
    \n#\r\
    \n####################################\r\
    \n:local Host \$host\r\
    \n/tool netwatch\r\
    \n:local Status [get [find where host=\"\$Host\"] status]\r\
    \n:local Comment [get [find where host=\"\$Host\"] comment]\r\
    \n:local Interval [get [find where host=\"\$Host\"] interval]\r\
    \n:local Since [get [find where host=\"\$Host\"] since]\r\
    \n:log info \"script=netwatch watch_host=\$Host comment=\\\"\$Comment\\\" status=\$Status interval=\$Interval since=\\\"\$Since\\\"\""
/system script add dont-require-permissions=no name=Data_to_Splunk_using_Syslog owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Collect information from Mikrotik RouterOS\r\
    \n# Jotne 2024\r\
    \n# Script name=Data_to_Splunk_using_Syslog\r\
    \n:log info message=\"script=version ver=5.6\"\r\
    \n# ----------------------------------\r\
    \n\r\
    \n# Auto update syslog server. 5.3-5.4.\r\
    \n# Change <your syslog dns name> to the dns of your syslog server.\r\
    \n# The update is disabled by default.  Remove the # from the two next line to use it.\r\
    \n\r\
    \n#:local mySyslog [resolve <your syslog dns name>]\r\
    \n#/system/logging/action/set [find where name=\"logserver\"] remote=\$mySyslog\r\
    \n\r\
    \n\r\
    \n# What data to collect.  Set to false to skip the section \r\
    \n:local SystemResource true\r\
    \n:local SystemInformation true\r\
    \n:local SystemHealth true\r\
    \n:local TrafficData true\r\
    \n:local AccountData true\r\
    \n:local uPnP true\r\
    \n:local Wireless true\r\
    \n:local AddressLists true\r\
    \n:local DHCP true\r\
    \n:local Neighbor true\r\
    \n:local InterfaceData true\r\
    \n:local CmdHistory true\r\
    \n:local CAPsMANN false\r\
    \n\r\
    \n:local Routing true\r\
    \n:local OSPF false\r\
    \n:local BGP false\r\
    \n\r\
    \n:local PPP true\r\
    \n:local IPSEC true\r\
    \n\r\
    \n# Get RouterOS main version (used to run different script on different version)\r\
    \n:local train [:tonum [:pick [/system resource get version] 0 1]] \r\
    \n\r\
    \n# Collect system resource\r\
    \n:if (\$SystemResource) do={\r\
    \n\t/system resource\r\
    \n\t:local cpuload [get cpu-load]\r\
    \n\t:local freemem ([get free-memory]/1048576)\r\
    \n\t:local totmem ([get total-memory]/1048576)\r\
    \n\t:local freehddspace ([get free-hdd-space]/1048576)\r\
    \n\t:local totalhddspace ([get total-hdd-space]/1048576)\r\
    \n\t:local up [get uptime]\r\
    \n\t:local sector [get write-sect-total]\r\
    \n\t:log info message=\"script=resource free_memory=\$freemem MB total_memory=\$totmem MB free_hdd_space=\$freehddspace MB total_hdd_space=\$totalhddspace MB cpu_load=\$cpuload uptime=\$up write-sect-total=\$sector\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Make some part only run every hours\r\
    \n:global Hour\r\
    \n:local run false\r\
    \n:local hour [:pick [/system clock get time] 0 2]\r\
    \n:if (\$Hour != \$hour) do={\r\
    \n\t:global Hour \$hour\r\
    \n\t:set run true\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get NTP status\r\
    \n:local ntpstatus \"\"\r\
    \n:if ([:len [/system package find where !disabled and name=ntp]] > 0 or [:tonum [:pick [/system resource get version] 0 1]] > 6) do={\r\
    \n    :set ntpstatus [/system ntp client get status]\r\
    \n} else={\r\
    \n    :if ([:typeof [/system ntp client get last-update-from]] = \"nil\") do={\r\
    \n        :set ntpstatus \"using-local-clock\"\r\
    \n    } else={\r\
    \n        :set ntpstatus \"synchronized\"\r\
    \n    }\r\
    \n}\r\
    \n:log info message=\"script=ntp status=\$ntpstatus\" \r\
    \n\r\
    \n\r\
    \n# Get interface traffic data for all interface\r\
    \n:if (\$TrafficData) do={\r\
    \n\t:foreach id in=[/interface find] do={\r\
    \n\t\t:local output \"\$[/interface print stats as-value where .id=\$id]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"if_traffic\"\r\
    \n\t\t:log info message=\"\$output\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get traffic data v2 (Kid Control)\r\
    \n:if (\$AccountData) do={\r\
    \n\t:foreach logline in=[/ip kid-control device find] do={\r\
    \n\t\t:local output \"\$[/ip kid-control device get \$logline]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"kids\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Finding dynmaic lines used in uPnP\r\
    \n:if (\$uPnP) do={\r\
    \n\t:foreach logline in=[/ip firewall nat find where dynamic=yes and comment~\"^upnp \"] do={\r\
    \n\t\t:local output \"\$[/ip firewall nat print as-value from=\$logline]\"\r\
    \n\t\t:set ( \"\$output\"->\"script\" ) \"upnp\"\r\
    \n\t\t:log info message=\"\$output\" \r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect system information 5.5 added ID for non routerBoard 5.6 Remvoed serial\r\
    \n:local model na\r\
    \n:local ffirmware na\r\
    \n:local cfirmware na\r\
    \n:local ufirmware na\r\
    \n:if (\$SystemInformation and \$run) do={\r\
    \n\t:local version ([/system resource get version])\r\
    \n\t:local board ([/system resource get board-name])\r\
    \n\t:local identity ([/system identity get name])\r\
    \n\t:do {\r\
    \n\t\t:if (\$board!=\"CHR\" OR \$board!=\"x86\") do={\r\
    \n\t\t\t/system routerboard\r\
    \n\t\t\t:set model ([get model])\r\
    \n\t\t\t:set ffirmware ([get factory-firmware])\r\
    \n\t\t\t:set cfirmware ([get current-firmware])\r\
    \n\t\t\t:set ufirmware ([get upgrade-firmware])\r\
    \n\t\t}\r\
    \n\t} on-error={}\r\
    \n\t:log info message=\"script=sysinfo version=\\\"\$version\\\" board-name=\\\"\$board\\\" model=\\\"\$model\\\" identity=\\\"\$identity\\\" factory-firmware=\\\"\$ffirmware\\\" current-firmware=\\\"\$cfirmware\\\" upgrade-firmware=\\\"\$ufirmware\\\"\"\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect system health\r\
    \n:if (\$train > 6 and \$SystemHealth) do={\r\
    \n\t# New version (RouterOS >6)\r\
    \n\t:foreach id in=[/system health find] do={\r\
    \n\t\t:local health \"\$[/system health get \$id]\"\r\
    \n\t\t:set ( \"\$health\"->\"script\" ) \"health\"\r\
    \n\t\t:log info message=\"\$health\"\r\
    \n\t}\r\
    \n} else={\r\
    \n\t# Old version (RouterOS 6 or older)\r\
    \n\t:if (!([/system health get]~\"(state=disabled|^\\\$)\")) do={\r\
    \n\t\t:local health \"\$[/system health get]\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n# Sends wireless client data to log server \r\
    \n:if (\$Wireless && [:len [/int find where type=wlan]]>0) do={\r\
    \n\t/interface wireless registration-table\r\
    \n\t:foreach i in=[find] do={\r\
    \n\t\t:log info message=\".id=\$i;ap=\$([get \$i ap]);interface=\$([get \$i interface]);mac-address=\$([get \$i mac-address]);signal-strength=\$([get \$i signal-strength]);tx-rate=\$([get \$i tx-rate]);uptime=\$([get \$i uptime]);script=wifi\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Count IP in address-lists\r\
    \n#----------------------------------\r\
    \n:if (\$AddressLists) do={\r\
    \n\t:local array [ :toarray \"\" ]\r\
    \n\t:local addrcntdyn [:toarray \"\"] \r\
    \n\t:local addrcntstat [:toarray \"\"] \r\
    \n\t:local test\r\
    \n\t:foreach id in=[/ip firewall address-list find] do={\r\
    \n\t\t:local rec [/ip firewall address-list get \$id]\r\
    \n\t\t:local listname (\$rec->\"list\")\r\
    \n\t\t:local listdynamic (\$rec->\"dynamic\")\r\
    \n\t\t:if (!(\$array ~ \$listname)) do={ :set array (\$array , \$listname) }\r\
    \n\t\t:if (\$listdynamic = true) do={\r\
    \n\t\t\t:set (\$addrcntdyn->\$listname) (\$addrcntdyn->\$listname+1)\r\
    \n\t\t} else={\r\
    \n\t\t\t:set (\$addrcntstat->\$listname) (\$addrcntstat->\$listname+1)}\r\
    \n\t}\r\
    \n\t:foreach k in=\$array do={\r\
    \n\t\t:log info message=(\"script=address_lists list=\$k dynamic=\".((\$addrcntdyn->\$k)+0).\" static=\".((\$addrcntstat->\$k)+0))}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get MNDP (CDP) Neighbors\r\
    \n:if (\$Neighbor and \$run) do={\r\
    \n\t:foreach neighborID in=[/ip neighbor find] do={\r\
    \n\t\t:local nb [/ip neighbor get \$neighborID]\r\
    \n\t\t:local id [:pick (\"\$nb\"->\".id\") 1 99]\r\
    \n\t\t:foreach key,value in=\$nb do={\r\
    \n\t\t\t:local newline [:find \$value \"\\n\"]\r\
    \n\t\t\t:if ([\$newline]>0) do={\r\
    \n\t\t\t\t:set value [:pick \$value 0 \$newline]\r\
    \n\t\t\t}\r\
    \n\t\t\t:log info message=\"script=neighbor nid=\$id \$key=\\\"\$value\\\"\"\r\
    \n\t\t}\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect DHCP Pool information\r\
    \n:if (\$DHCP and \$run) do={\r\
    \n\t/ip pool {\r\
    \n\t\t:local poolname\r\
    \n\t\t:local pooladdresses\r\
    \n\t\t:local poolused\r\
    \n\t\t:local minaddress\r\
    \n\t\t:local maxaddress\r\
    \n\t\t:local findindex\r\
    \n\r\
    \n# Iterate through IP Pools\r\
    \n\t\t:foreach pool in=[find] do={\r\
    \n\t\t\t:set poolname [get \$pool name]\r\
    \n\t\t\t:set pooladdresses 0\r\
    \n\t\t\t:set poolused 0\r\
    \n\r\
    \n# Iterate through current pool's IP ranges\r\
    \n\t\t\t:foreach range in=[:toarray [get \$pool range]] do={\r\
    \n\r\
    \n# Get min and max addresses\r\
    \n\t\t\t\t:set findindex [:find [:tostr \$range] \"-\"]\r\
    \n\t\t\t\t:if ([:len \$findindex] > 0) do={\r\
    \n\t\t\t\t\t:set minaddress [:pick [:tostr \$range] 0 \$findindex]\r\
    \n\t\t\t\t\t:set maxaddress [:pick [:tostr \$range] (\$findindex + 1) [:len [:tostr \$range]]]\r\
    \n\t\t\t\t} else={\r\
    \n\t\t\t\t\t:set minaddress [:tostr \$range]\r\
    \n\t\t\t\t\t:set maxaddress [:tostr \$range]\r\
    \n\t\t\t\t}\r\
    \n\r\
    \n# Calculate number of ip in one range\r\
    \n\t\t\t\t:set pooladdresses (\$maxaddress - \$minaddress)\r\
    \n\r\
    \n# /foreach range\r\
    \n\t\t\t}\r\
    \n\r\
    \n# Test if pools is used in DHCP or VPN and show leases used\r\
    \n\t\t\t:local dname [/ip dhcp-server find where address-pool=\$poolname]\r\
    \n\t\t\t:if ([:len \$dname] = 0) do={\r\
    \n# No DHCP server found, assume VPN\r\
    \n\t\t\t\t:set poolused [:len [used find pool=[:tostr \$poolname]]]\r\
    \n\t\t\t} else={\r\
    \n# DHCP server found, count leases\r\
    \n\t\t\t\t:local dname [/ip dhcp-server get [find where address-pool=\$poolname] name]\r\
    \n\t\t\t\t:set poolused [:len [/ip dhcp-server lease find where server=\$dname]]}\r\
    \n\r\
    \n# Send data\r\
    \n\t\t\t:log info message=(\"script=pool pool=\$poolname used=\$poolused total=\$pooladdresses\")\r\
    \n\r\
    \n# /foreach pool\r\
    \n\t\t}\r\
    \n# /ip pool\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Get detailed command history RouterOS >= v7\r\
    \n:if (\$train > 6 and \$CmdHistory) do={\r\
    \n\t:global cmd\r\
    \n\t:local f 0\r\
    \n\t:foreach i in=[/system history find] do={\r\
    \n\t\t:if (\$i = \$cmd) do={ :set f 1 }\r\
    \n\t\t:if (\$f != 1) do={\r\
    \n\t\t\t:log info message=\"StartCMD\"\r\
    \n\t\t\t:log info message=[/system history get \$i]\r\
    \n\t\t\t:log info message=\"EndCMD\"\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\t:global cmd  [:pick [/system history find] 0]\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Test if CAPsMANN is installed and run script 5.5\r\
    \n:if ( ([:len [/interface find where type=\"cap\"]] > 0) and \$CAPsMANN) do={ \r\
    \n\t/system script run CAPsMANN\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n# Collect routing information\r\
    \n:if (\$Routing) do={\r\
    \n\t/ip route\r\
    \n\t:foreach id in=[find] do={\r\
    \n\t\t:local route \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$route\"->\"script\" ) \"route\"\r\
    \n\t\t:log info message=\"\$route\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$OSPF) do={\r\
    \n\t/routing ospf neighbor\r\
    \n\t\t:local ospf \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ospf\"->\"script\" ) \"ospf\"\r\
    \n\t\t:log info message=\"\$ospf\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$BGP) do={\r\
    \n\t/routing bgp session\r\
    \n\t\t:local bgp \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$bgp\"->\"script\" ) \"bgp\"\r\
    \n\t\t:log info message=\"\$bgp\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Collect PPP/IPSEC\r\
    \n:if (\$PPP) do={\r\
    \n\t/ppp active\r\
    \n\t\t:local ppp \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ppp\"->\"script\" ) \"ppp\"\r\
    \n\t\t:log info message=\"\$ppp\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n:if (\$IPSEC) do={\r\
    \n\t/ip ipsec active-peers\r\
    \n\t\t:local ipsec \"\$[get \$id]\"\r\
    \n\t\t:set ( \"\$ipsec\"->\"script\" ) \"ipsec\"\r\
    \n\t\t:log info message=\"\$ipsec\"\r\
    \n\t}\r\
    \n}\r\
    \n\r\
    \n# End Script\r\
    \n\r\
    \n"
/system script add dont-require-permissions=yes name=Netwatch-JRS-small owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":local Host \$host\r\
    \n/tool netwatch\r\
    \n:local thisBox [/system identity get name];\r\
    \n:tool e-mail send to=XXXXX@XXXXX.com subject=\"\$thisBox DOWN to \$Host\" body=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \"\$thisBox DOWN to \$Host\" )\r\
    \n"
/system script add dont-require-permissions=yes name=script2 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n/system\r\
    \n\r\
    \n\r\
    \n\r\
    \n#:local logIDs [/system logging find where topics~\"info,!script\"]\r\
    \n\r\
    \n#/system logging set \$logIDs disabled=yes\r\
    \n\r\
    \n/system/logging/disable numbers=[/system logging/find where topics~\"info\"] \r\
    \n\r\
    \n:log info \$logIDs\r\
    \n\r\
    \n\r\
    \n/system/logging/enable numbers=[/system logging/find where topics~\"info,!script\"] \r\
    \n\r\
    \n#/system logging set \$logIDs disabled=no\r\
    \n\r\
    \n\r\
    \n# :log info (\"Uploaded rsc backup to 192.168.2.22 as \".\$identitydate)\r\
/system ups add name=ups1 port=usbhid1
/system watchdog set auto-send-supout=yes ping-start-after-boot=10m ping-timeout=10m send-email-from=XXXXX@XXXXX.com send-email-to=XXXXX@XXXXX.com watch-address=1.1.1.1
/tool bandwidth-server set authenticate=no
/tool e-mail set from=XXXXX@XXXXX.com port=587 server=smtp.gmail.com tls=starttls user=XXXXX@XXXXX.com
/tool graphing interface add interface=bridge
/tool graphing queue add
/tool graphing resource add
/tool mac-server set allowed-interface-list=MANAGE
/tool mac-server mac-winbox set allowed-interface-list=MANAGE
/tool netwatch add comment=Netwatch-8.8.4.4-Splunk disabled=no down-script=Netwatch host=8.8.4.4 http-codes="" interval=30s name=Netwatch-8.8.4.4-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.0.11-Splunk disabled=no down-script=Netwatch host=192.168.0.11 http-codes="" interval=30s name=Netwatch-192.168.0.11-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.20.1-Splunk disabled=no down-script=Netwatch host=192.168.20.1 http-codes="" interval=30s name=Netwatch-192.168.20.1-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.30.2-Splunk disabled=no down-script=Netwatch host=192.168.30.2 http-codes="" interval=20s name=Netwatch-192.168.30.2-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.40.1-Splunk disabled=no down-script=Netwatch host=192.168.40.1 http-codes="" interval=30s name=Netwatch-192.168.40.1-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.70.1-Splunk disabled=no down-script=Netwatch host=192.168.70.1 http-codes="" interval=30s name=Netwatch-192.168.70.1-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.20.22-Splunk disabled=no down-script=Netwatch host=192.168.20.22 http-codes="" interval=30s name=Netwatch-192.168.20.22-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.1.2-Splunk disabled=no down-script=Netwatch host=192.168.1.2 http-codes="" interval=30s name=Netwatch-192.168.1.2-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-JRS-small disabled=no down-script=Netwatch-JRS-small host=1.1.1.1 http-codes="" interval=30s name=Netwatch-JRS-small test-script="" type=simple up-script=Netwatch-JRS-small
/tool netwatch add comment=Netwatch-192.168.0.80-Splunk disabled=no down-script=Netwatch host=192.168.0.80 http-codes="" interval=30s name=Netwatch-192.168.0.80-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.0.32-Splunk disabled=no down-script=Netwatch host=192.168.0.32 http-codes="" interval=30s name=Netwatch-192.168.0.32-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.0.31-Splunk disabled=no down-script=Netwatch host=192.168.0.31 http-codes="" interval=30s name=Netwatch-192.168.0.31-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.2.5-Splunk disabled=no down-script=Netwatch host=192.168.2.5 http-codes="" interval=30s name=Netwatch-192.168.2.5-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.2.7-Splunk disabled=no down-script=Netwatch host=192.168.2.7 http-codes="" interval=30s name=Netwatch-192.168.2.7-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.20.5-Splunk disabled=no down-script=Netwatch host=192.168.20.5 http-codes="" interval=30s name=Netwatch-192.168.20.5-Splunk test-script="" type=simple up-script=Netwatch
/tool netwatch add comment=Netwatch-192.168.20.21-Splunk disabled=no down-script=Netwatch host=192.168.20.21 http-codes="" interval=30s name=Netwatch-192.168.20.21-Splunk test-script="" type=simple up-script=Netwatch
/tool romon set enabled=yes
/tool sniffer set file-limit=10000KiB filter-ip-address=10.0.0.0/16 memory-limit=10000KiB streaming-server=192.168.2.22
/tool traffic-monitor add disabled=yes interface=ether1 name=tmon1
/tool traffic-monitor add disabled=yes interface=ether3 name=tmon2 traffic=received trigger=always
