Script runs fine from CLI, but not webinterface or netwatch
Quick one for the experts, I have the following script
1   name="SMS_Test" owner="admin" last-started=mar/07/2014 15:19:22 run-count=11 source=
       :log info "CHECK_SERVICES: Sending SMS"
       /tool fetch \
         mode=https \
         host="www.voipbuster.com" \
         url="https://www.voipbuster.com/myaccount/sendsms.php?username=XXXXXXX&password=XXXXX&from=gateway&to=+31611XXXXXX&text=AllOK" \
         keep-result=no
When I run this script from the CLI, it runs fine and voipbuster sends me an SMS. When I run it via the RUN button inside the WEB nothing happens neither does netwatch when calling from a Down.
I must be doing something stupid, but just can’t figure out what. (that’s why it’s called stupid.)
RouterOS version?
Routerboard model?
:smiley:
Routerboard: 2011UiAS-2HnD
Firmware: 3.10
RouteOS: 6.1
I knew my post was incomplete
On the 2011UiAS-2HnD run RouterOS 6.7 at least (bios 3.10), or wait for 6.11, but never use 6.8, 6.9 or 6.10.
I have tried this script and on my 2011UiAS-2HnD [exactly RB2011UiAS-2HnD-IN] with 6.10 (and bios 3.12) are working.
Bios 3.12:
http://i.mt.lv/routerboard/files/ar9344_3.12.fwf
(copy to file folder and symply go to system routerboard to upgrade)
What? I just write to you to not use 6.10 but I’m using 6.10!!!
It’s not a joke. you can use 6.10 if in your routerboard not use pppoe with encryption (or any type of mppe encryption)
There is described the bug http://forum.mikrotik.com/t/problem-with-mount-point/94/1
The bug are solved on 6.11rc1
Euhhhh,
Thanx (I Think)? I upgraded to the latest version on both my devices, and attempted to run the script again. Once again the fetch does not work. The debug line works fine. Might this be an issue with the telephone number? in the URL it has +316115xxxxxx
Anyone?
Okay so I tried everything I could think which included the following:
encoded all the URL strings: works fine from CLI, NOK fro netwatch or web interface
Put all the stuff into variables: again fine from CLI, NOK from netwatch or web interface
Put all the stuff int vars and encoded them: same as above.
Be sure to have set at minimum policy=test for the script or the scheduler
Dirk
