script to check ipsec tunnel
I have a script that flushes the IPSEC SA list if a the other end is not reachable by ping (which happens often and after flushing the SA list the connection reconnects) but I have added a second IPSEC tunnel with the same problem but the peer will not allow ICMP.
Original Ping script i copied from some other place in the forums.
:if ([/ping 10.6.51.11 interval=3 count=3]<2) do={
:log warning "IPSec KO, flushing SAs"
/ip ipsec installed-sa flush sa-type=all
} else={
:log info "IPSec OK"
I want to change this script to check how many remote peers are in ipsec instead of ping
/ip ipsec remote-peers print
any ideas?
something like this?
local peer [len [ip ipsec remote-peers find ]]
put $peer
Thanks for the idea.
I am really bad at this scripting but to test out your idea I did this:
local peer [len [/ip ipsec remote-peers print ]]
put $peer
log info $peer
No matter if I had an IPSEC connection or not it always put 0 in the log.
sorry, try this
put $peer
log info $peer
I think this worked!
[/ping 172.21.10.47 interval=3 count=3]
put $peer
log info $peer
:if ($peer<2) do={
} else={
The pings at the beginning are to initiate the connection and are not monitored because the other end is blocking ICMP.
