Script to clear ARP
I’m trying to write a script under Mikrotik 4.13 to clear ARP tables.
Right now I’ve got:
:put "Removing NAT..."
:local arpCount [/ip arp print count-only];
for i from=0 to=$arpCount do={
:put "/ip arp remove $i;"
/ip arp remove $i;
and the script output is always:
> /system script run deleteARP
Removing NAT...
4
/ip arp remove 0;
interrupted
           no such item
Please can anyone tell me why the command /ip arp remove numbers=$i is not working correctly and how to solve this?
Thanks for any help!
/ip arp remove [find]
(May fail if arp table is empty)
it fails because ARP table is dynamic and while your script runs - some entries can be removed, that causes the problem.
Try this script:
:local dumplist [/ip arp find]
:foreach i in=$dumplist do={
    /ip arp remove $i
Hi there!
In the arp section on Terminal (i.e., /ip arp ), uou should use
remove [find]
or
:foreach ip in={[find]} do={remove "$ip"}
Hope it helps!
Thanks!
