# Script to ensure wireless lan radio Power Safer is ON or OFF # # To use in Tropical, Hot Countrys, where have extremly
To use in Tropical, Hot Countrys, where have extremly high Daytime Temperatures
between user selected times
The radio ON/OFF operation will not be performed if the system
clock is not in sync with local time, unless so required
Remember router is set back to default time after a reboot
Schedule this script at required intervals
Power Safer ON ( /interface $RadioName tx-power=20 tx-power-mode=all-rates-fixed )
Power Safer OFF ( /interface $RadioName tx-power-mode=default )
Set the Radio Power Safer ON and OFF times here
:local SaferOnTime "07:00";
:local SaferOffTime "20:00";
set to "no" if clock is being set manually after each reboot
set to "yes" if clock is being set using NTP client
:local UseNTPClientStatus "yes";
:log info "RadioOnOff Script Starting";
get the name of the wlan radio interface
:local RadioName [/interface get [find type=wlan] name];
:log info "Radio Name = $RadioName";
First check if system clock has been syncronized with local time
:local NTPSyncState [/system ntp client get status];
:log info "NTP Client Status = $NTPSyncState";
Don't perform radio On or Off operation, if current real time is unknown, unless required
:if (($NTPSyncState="synchronized") or ($UseNTPClientStatus="no")) do {
:local CurrentTime [/system clock get time];
:log info "Current Time = $CurrentTime";
Check current ON or OFF status of Safer Mode
:local SaferOff [/interface get $RadioName default tx-power-mode]; # I think the Problem is here !!! #
:log info "Safer Off = $Radio Safer Off";
Where the ON time is set earlier than the OFF time
:if ($SaferOnTime < $SaferOffTime) do {
Radio should be ON between these times
:if (($CurrentTime > $SaferOnTime) and ($CurrentTime < $SaferOffTime)) do {
if ($SaferOff=true) do {
:log info "Safer was OFF, now switching ON";
/interface set $RadioName tx-power=20 tx-power-mode=all-rates-fixed;
} else {
if ($SaferOff=false) do {
:log info "Safer was ON, now switching OFF";
/interface set $RadioName tx-power-mode=default;
Where the ON time is set later than the OFF time
:if ($SaferOnTime > $SaferOffTime) do {
Safer should be OFF between these times
:if (($CurrentTime < $SaferOnTime) and ($CurrentTime > $SaferOffTime)) do {
if ($SaferDisabled=false) do {
} else {
if ($SaferDisabled=true) do {
} else {
:log info "System clock may not be synchronized to local time, unable to perform operation";
:log info "SaferOnOff Script completed";
This Script doesn't Work, Who can Help me to edit the Script to Run with Router Os 6.31, I've createt a Hotspot Network with any Groove's in WDS, Antena Omni Hyperlink 15 Dbi, my Link is only for Android and Portable Devices, I do not work with long distances, Iám living in Brazil and here we have very high Daytime Temperatures, Groove comes over 55C, because this I think is better to work with low TX Power by Day and use Default TX Power by the Night.
What about having two scrips (on/off) running by scheduler in desired time instead continuously run a script that would be checking the time?
