Script to List MAC addresses in Bridge Filters
Hey all,
Trying to list the MAC addresses in bridge filters but not having any luck. Here is what I have:
:foreach i in=[/interface bridge filter] do={
:local localmac [/interface bridge filter get $i src-mac-address]
:log warning “Found ths MAC Address in $localmac”
Any help would be appreciated, please.
With thanks
Depending on your device switch implementation, you may not see mac address this way.
Do you get any output from this?
/interface bridge filter print
I guess no.
Try this instead:
/ip arp print
You will not see what mac address its connected to what port, it port is part of a bridge. You will then see mac connected to the bridge instead.
:foreach i in=[/ip arp find] do={
:local localmac [/ip arp get $i mac-address]
:log warning "Found ths MAC Address in $localmac"
Thanks for the response, your script lists Mac from the ARP list, what I’m looking to do is to list the MAC from the bridge filter list…
Thanks anyway :slight_smile:
Then try this:
/interface bridge host
:foreach i in=[find] do={
:local localmac [get $i mac-address]
:put "Found ths MAC Address in $localmac"
To see all information
/interface bridge host print
Thank you for your help,
Got it in the end :slight_smile:
:local localmac [get $i src-mac-address]
:log warning “Found ths MAC Address in $localmac In the Filter List”
