Hi!
I am running Latest 6.0 RC version on several locations and different hardware(RB1000, RB450G, RB2011…), and on all of them there is a same problem.
After opening and editing any of my scripts and applying changes, they are sometimes applied and sometimes not. After unsuccessful apply, you cannot start terminal (you can but there is no prompt!!), so you can only reboot router (from GUI) hoping that next time will be better.
Sometimes after restart all the scripts an scheduled tasks are missing so you need to restart again…
Is it me, or there is a known issue with this?
regards
