Scripting language
Hi, I am comfused what programming language RouterOS uses for scripting?
Option 1: Is it called “MikroTik scripting language”? http://wiki.mikrotik.com/wiki/Manual:Scripting
Option 2: It uses Lua scripting language? http://wiki.mikrotik.com/wiki/Manual:Lua
Option 3: Use MikroTik scripting language when Lua is extension from ROS version 4
there is no Lua, read the first sentence of the article you posted :slight_smile:
RouterOS v4 RC1 removes Lua support indefinetly
correct answer: “MikroTik scripting language”
thank you, my mistake :blush:
