Scripts Value !
Hi every one ..
there is a value or var. used with commands in scripts .. just like FIND USER which it excuet some useful in many way
just like the script which provided to me by member sergejs
‘ip hotspot active remove [find user=name]’
and so forth .. quastion is this term [find user=name]
how could i create diffreant one .. and what is the way make me able to creat like this items ..
thanks for reading and replay
RTFM
http://www.mikrotik.com/testdocs/ros/2.9/system/scripting.php
there you will find almost all commands, script syntax and variable definitions.
