Second gateway not working
I have 2 ISP links on eth1 and eth2, and I want to set up a kind of fail-over for LAN (connected to eth3), so I started with the simplest (though incomplete) way of doing it, as described here: http://wiki.mikrotik.com/wiki/Two_gateways_failover. But I can’t get it working. When I unplug the cable from eth1 or disable the first gateway, the second gateway becomes active but the connection drops. Internet sites don’t even ping from the router.
Here’s my setup:
/ip address add address=11.11.11.2/28 interface=eth1-isp1
/ip address add address=22.22.22.2/28 interface=eth2-isp2
/ip address add address=192.168.1.1/24 interface=eth3-lan
/ip firewall nat add chain=srcnat action=masquerade out-interface=eth1-isp1
/ip firewall nat add chain=srcnat action=masquerade out-interface=eth2-isp2
/ip route add gateway=11.11.11.1 check-gateway=ping
/ip route add gateway=22.22.22.1 distance=2
Could anyone, please, tell me what’s wrong here?
tracert google.com
on windows machine
From the configurations that you’ve posted everything seems OK. From what you’ve posted, you should be able to ping 22.22.22.1 or 11.11.11.1 from any LAN PC, unless you have a firewall blocking ICMP packets.
Make sure that you don’t have a master-port set on the eth2-isp2 interface.
Either its that, OR you haven’t specified a route for eth2-isp2 outside the 22.22.22.2/28 range.
You should also check if you can ping via both interfaces (without disabling 1) from the router using Tools → Ping and selecting the appropriate interface.
Thank you guys for the response. Of course, nothing was wrong with my configuration. It just turned out that, although the ISP2 ensured me that I can use the whole 22.22.22.1/28 subnet, some addresses just don’t work, including 22.22.22.2 – the one that I had assigned to eth2-isp2. So I experimentally found out witch addresses do work, and soon as I changed eth2-isp2 to a working address, everything was ok.
