I have multiple devices on my LAN and I am segregating them for security purposes into 3 groups using 3 VLANs (2 tagged, one untagged). All the devices are connected to a managed VLAN aware switch.
Now, I want to connect those devices to the Internet via a MTK router (I’m currently playing with a RB750Gr2). I would like to have different firewall and routing rules for each VLAN.
I could connect each VLAN to a separate port of the router and it looks that there is enough flexibility for the purpose, however, the more elegant way is to use a trunk port for all the VLANs together. It is there that I am stumped with the following issues:
I cannot make a filter condition based on VLAN id. There is no such field in the filters. Also I cannot use the VLAN interface as a condition, as the firewall complains that it is a slave I/F (I’m bridging the Eth I/F with the VLAN I/F’s) . I obviously cannot use the source IP address also since an intruder can choose any IP address for the device.
I do not see how I disable the inter-VLAN routing.
I thought of using the DHCP server of RouterOS instead of a server, for one less point of failure. I don’t see how I can use different address pools for each VLAN.
I resolved this by using bridges. Create a bridge for each VLAN. Then add each VLAN into the respective bridge as a port. From there, assign the IP address to the bridge for each VLAN.
By segregating each VLAN with a unique IP address, you can then use IP Firewall filters to control inter VLAN routing.
What I do is create an Approved Address list for each VLAN,
Then I create three filter rules for each VLAN:
Rule Number 1: All traffic From VLAN1-Adddress-List to talk to VLAN1-Addresss-List
Rule number 2: Allow traffic from VLAN1-Address-List to talk to The Internet Interface
Rule Number 3: Drop all traffic from VLAN1/Bridge1 that is !VLAN1/Bridge1
Will the bridge ports include the physical ethernet port or have only one entry, i.e. the VLAN. If only the VLAN, why the bridge at all ? Else, if the ethernet is included, can I drop untagged frames at the bridge ?
In general I saw the VLAN bridge examples and I did not understand the need for a bridge - in my tests I can attach an IP address to the VLAN interface itself, and I could ping that.
Is there any definition to be made at the switch level ?
