Sending Mail when BGP is down Script error
I’ve recently implemented a script (found on the internet), to monitor my BGP peers, so when one bgp peer goes down, I will get informed with a mail. The problem is that the script seems to not working (not sending mail). The mail tool has been configured and is working when I manually send an email.
The script is shown bellow:
# EDIT HERE
:local arrEmails [:toarray "mail@mail.com"];
:local debug false
# EDIT END
# Define Variables
:global arrBgpState;
:global gotKey false;
:local hostNameX ([/system identity get name]);
:local statusX;
:local peerX;
:local peerXarrEl;
:local mailToX;
:local mailSubjectX;
:local mailBodyX;
:local peerStatusX;
:local arrBgpPeers [:toarray ""];
:local peername "";
:local peerTotal "";
if ($debug = true) do={
   :log info ("=============BGP PEER STATUS DETECTION STARTED=============" )
# Initialize global array - kinda lame way to do it :P
:if ( [:len $arrBgpState] =0 ) do={
   :set $arrBgpState {"false"="false"}
# Fill arrBgpPeers array with peers name
:foreach i in=[/routing bgp peer find] do={
:set peername [/routing bgp peer get $i name];
:set peerTotal ($peerTotal . "," .$peername);
:set arrBgpPeers [:toarray $peerTotal];
# Loop through the peers array
:local arrPos
:for arrPos from=0 to=([:len $arrBgpPeers]-1) do={
   # Set peerX to current peer name for this iteration
   :set peerX [:pick $arrBgpPeers $arrPos];
   # Check if peer is enabled and proceed
   :if ([/routing bgp peer get [find name=$peerX] disabled ] != true) do={
      # Get Peer Status
      :set peerStatusX [/routing bgp peer get [find name="$peerX"] state]
      # Find peer key in global array
      :foreach k,v in=$arrBgpState do={
         if ($k != "false") do={
            :if ($gotKey = false) do={
               :if ($k = $peerX) do={
                  :set gotKey true
      # Initialize arrBgpState array element with peerX name if it doesn't already exist
         :set ($arrBgpState->"$peerX") "up"
      # Reset this for the next iteration
      :set gotKey false
      # Previous run peer status
      :set statusX ($arrBgpState->"$peerX")
      # Prepare Email body
      :set mailBodyX ("Router Hostname: " . $hostNameX . "\nBGP Peer Status: " . $peerStatusX . "\nBGP Peer Name: " . $peerX . "\n");
      # Check if BGP Peer is not established
      :if ($peerStatusX != "established") do={
          # Check if this is the first time the peer is doen
          :if ( $statusX  = "up" ) do={
            # Set value to 'down' to peer global var key
            :set ($arrBgpState->$peerX) "down"
            # Informational Log
               :log error ("BGP Peer ". $peerX ." state is " . $peerStatusX . ". Sending email alerts!" )
            # Prepare Email subject
            :set mailSubjectX ("BGP Peer ". $peerX ." on ". $hostNameX . " is NOT established!");
            # Loop over emails array to send emails to all recipients in array
            :local arrPos2
            :for arrPos2 from=0 to=([:len $arrEmails]-1) do={
               # Set mailToX to recipient for this iteration
               :set mailToX [:pick $arrEmails $arrPos2]
               # Informational Log
               :log error ("BGP Peer " . $peerX . " status is " .$peerStatusX. "! Sending Email alert to " . $mailToX . "." )
               # Send Email
               /tool e-mail send to=$mailToX subject=$mailSubjectX body=$mailBodyX start-tls=yes;
         } else={
            # Peer down. Already sent notification so do nothing.
               :log info ("BGP Peer ". $peerX ." is already down. Ignoring!")
      } else={
         # Check if peer just came back up and send informational email
         if ($statusX = "down") do={
            :set mailSubjectX ("BGP Peer ". $peerX ." on ". $hostNameX . " has recovered!");
            :local arrPos2
               # Set mailToX to recepient for this iteration
               # Informational Log
               :log warning ("BGP Peer " . $peerX . " status has recovered! Sending informational Email to " . $mailToX . "." )
               # Send Email
            :log info ("BGP Peer " . $peerX . " is up. Nothing to do!")
         # Set peer status to up
         :set ($arrBgpState->$peerX) "up"
   } else={
         :log warning ("BGP Peer " . $peerX . " is disabled. Ignoring!")
   :log info ("=============BGP PEER STATUS DETECTION ENDED===============" )
The error shown in the logs is the following :
Topics
script
error
Message BGP Peer status is idle! Sending Email alert to > mail@mail.com> .
Can someone please help me identify the issue?
Model of router: CCR1072-1G-8S+
Version of RouterOS: 6.39.2
I’m still trying to figure out what is wrong with the script.
So if anyone has any insight, please do provide any kind of feedback.
Thank you.
Did you change the email address in 2nd line?
Yes I did. I have already tested the script but cannot find the reason to why when i manually send an email , all is good, but when the script runs i get no email.
Hi
Your script worked perfectly for me, only thing I changed:
Send Email
To
Send Email
/tool e-mail send to=$mailToX subject=$mailSubjectX body=$mailBodyX start-tls=tls-only;
Hi, does anyone have a BGP is down script error for v7?
Im also looking for a similar script for V7
I wrote something, in Python to run off the router on my monitoring host. This will also alert you if there is a session defined in /routing/bgp/connection but it doesn’t appear in /routing/bgp/sessions as well as sessions which are not established in /routing/bgp/sessions.
https://github.com/edgenative/mikrotik-bgpmon
Hello, could someone advise with solution to:
  • I’m using this script and it sends warnings to email address;
  • I’m experiece BGP sessions drops from time to time and if so I had to switch BGP peer down and up to restore BGP session;
  • I’d like this script to do peer off/on automaticly, when it detect broken BGP session;
any sugestion?
Thaks in advance for help.
Daniel
