Serial terminal question
Is possible to send comand direct to serial port without using serial-terminal ? I have reseting tool for IP camera but for reset I need to login into MT and put command in serial-terminal console.
But this could be done by sending command direct and automatic on host down from netwatch…
Thanks.
You can attach the serial port on a routerboard to a special-login user that will allow you to get direct access to it via ssh if that helps.
http://wiki.mikrotik.com/wiki/Serial_Port_Usage#Accessing_a_serial_device_directly_by_SSH_.2F_telnet_.2F_mac-telnet
