services ports
HI,
I wonder what is the difference if I disable port in /ip services list or in /ip firewall service-port
It’s two completely different things:
“/ip services” are services running on router. If you disable ftp, you disable router’s own ftp service.
“/ip firewall service-port” are helpers for connection tracking and NAT. If you disable ftp, you won’t be able to mark data connections as related and active mode won’t work for clients behind NAT.
Great Answer for me .
Thank you so Much :smiley:
