How do we rate limit an entire interface ? Outgoing traffic ?
the interfaces on the router for example are Ethernet1, E2
Want to rate limit Ethernet1 to 35mbps and E2 Outgoing to 40mbps
How can this be achieved ?
See the example near the bottom of this page.
http://www.mikrotik.com/docs/ros/2.8/root/queue.content
Regards
Andrew
If I have 4 interfaces to the net and i want to set for each individually the example does not show that. How to set the external speed on the network card to a set speed for incoming / outgoing and to do this for multiple card each having its own speed setting ?
Why not just use “/interface set ether1 tx-rate= rx-rate=”?
Command might not be 100% accurate - can’t check anywhere right now… ![]()
True. The example is for one interface only. You have to add additional queues for your extra interfaces.
Regards
Andrew
/queue simple add interface=ether1 limit-at=0/36700160 max-limit=0/36700160
/queue simple add interface=e2 limit-at=41943040/0 max-limit=41943040/0
or something like that
