Set Mikrotik For Esxi vms firewalls
Hello, I want to put 1 Mikrotik server in Esxi for the firewall of other servers
How can I do this?
All passing traffic must be done from the same Mikrotik server.
You could do a physical device physically in front of the VMWare Server
You could have a RouterOS VM, and set the VM’s to a private network that gateways through the RouterOS VM which has an interface both in the private network and a public network.
Configuration beyond that would be best asked on a ESXi community forum.
You make a virtual switch to which your local VMs are connected, and the MikroTik CHR also has a port there. The CHR also has a connection to another virtual switch that is connected to the external network.
You can also do the same using VLANs on a single switch.
Do not start many topics on the same subject: http://forum.mikrotik.com/t/esxi-and-mikrotik-firewall/163962/1
