Here’s my dilemma: I’m looking for directions into setting two Mikrotiks (currently in bridge) with my Raspberry Pi Zero to run both an Web/Mail Server.
I already connected my Raspberry Pi into the CRS125-24G-1S-IN (Router 2) through USB and the same is recognized as an LTE device by RouterOS. I have the CRS125 (Router 2) connected to a hEX S (Router 1) 300 meters from me, which is where the WAN - ONT (fiber converter) is connected.
Strangely enough, sometimes I can’t ping or SSH my Raspberry Pi at it’s subnet - 192.168.0.1 from my PC. I added the masquerade rule with out interface as the Raspberry Pi (LTE) on the CRS125(Router 2). When the Pi is accessible, in order to reach the Internet (WAN) that is located on Router 1 I also need to add a masquerade rule on Router 2 for the out interface: bridge, which slows down drastically the Router 2 performance and internet speed.
I basically need the Pi to have a stable connection with my computer and to access WAN (Internet). I’m also wondering how should I setup my firewall to use my Public IP address - 192.45.67.193 for accessing the website and mail server. I’m aware about basic forwarding rules for ports 80, 443, 993 so far. But no idea how to apply the basic principles on Mikrotik as I’m still learning it.
Here is the full diagram of my current setup including all the config files for both routers:
hEX S - Router 1:
add admin-mac=*************** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether2 ] comment=WAN (ONT)
set [ find default-name=ether3 ] comment=WIFI
set [ find default-name=ether4 ] comment=DEVICE
set [ find default-name=ether5 ] comment=ROUTER_2
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=ether2 name=vlan10 vlan-id=10
add interface=ether2 name=vlan30 vlan-id=30
/interface pppoe-client
add add-default-route=yes comment=ISP disabled=no interface=vlan10 \
keepalive-timeout=disabled name=pppoe-out1 password=***** service-name=\
use-peer-dns=yes user=****@*****
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/interface detect-internet
set detect-interface-list=all
192.168.88.0
/ip dhcp-client
add disabled=no interface=vlan30
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat out-interface=vlan30
ipsec-policy=out,none out-interface=pppoe-out1
CRS125-24G-1S-IN - Router 2:
add name=bridge1
/interface lte
set [ find ] name=lte1
add name=dhcp_pool0 ranges=\
192.168.88.1-192.168.88.2,192.168.88.4-192.168.88.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=ether4 comment=PC
add bridge=bridge1 interface=ether2 comment=ROUTER_1
add address=192.168.88.3/24 interface=bridge1 network=192.168.88.0
add address=192.168.1.1/24 interface=lte1 network=192.168.1.0
/ip dhcp-client
add disabled=no interface=lte1
add disabled=no interface=bridge1
add address=192.168.88.0/24 gateway=192.168.88.3
add action=masquerade chain=srcnat out-interface=lte1
Any help is very appreciated! Thanks
