I hope you are fine
I have 2 IP ranges in the network (192.168.10.0 and 192.168.20.0) which are routed together and I need to set up a hotspot
I connected the internet to the router from port number 1
I set up a hotspot on port 2 for the 192.168.10.0 network
I set up a hotspot on port 3 for the 192.168.20.0 network
After setting up the hotspot for these 2 network ranges, unfortunately, the routing between these 2 ranges is disabled !
what’s the solution ?
Please guide me, thank you
