Hi!
My non-profitable organisation is creating a wireless network for the city.
The network will have six APs.
Yellow marked APs are with no psychical internet connection, so connection needs to be linked from the red ones.
AP1 is located in the old town where all buildings are the same height. The only problem can be a park (marked with blue rectangle) where the height of the trees is above the buildings.
AP2 is an ideal spot, there are no psychical obstacles as well as the AP3
AP4 is a sports centre where we need to make a hotspot for the arena and cover blue marked areas.
AP5 has great optical visibility, but there is no psychical internet connection, so we have to link from AP6
AP6 will be located on the tower from where you can see the area within the red circle, but the distance is about 2.5km
Since this is a touristic place, there is a lot of restaurants, bars, etc. and the 2.4Ghz spectrum is crowded, I was thinking about making a 5Ghz network.
My question now is:
Which RBs and antenna are the best to use?
(The network will presumably have about 1000 users.) (all the APs should cover 360°)
Is the best solution for users to use SXT as a client, or RB with an external antenna.
I can’t think of anything else to ask at the moment, so if I have any more questions I will further ask during the discussion.
Thank’s in advance!
**EDIT: I was thinking about something like this:
RB800 - it’s about 2652,25kn (354€)
3x r52nM - 802.11 a/b/g/n - it’s 382,9kn (51€)
3x UBNT AM-5G19-120 antenna - it’s 1.207,21kn (160,96€)
TOTAL: approx. 10 000kn (1335€)**
