Hi! I have a very noob question regarding the configuration of an RB260GSP with the 2.11 firmware
I have followed the Mikrotik wiki guides and everything works fine in my network. However, I’m configuring the switch plugging a cable in one port and browsing to 192.168.88.1. I would like to access the SWOS web interface through my maintenance VLAN, but I am not sure how to do it.
My network has a router-on-a-stick design, having a trunk that communicates my pfSense firewall/router with my RB260GSP switch through 4 VLANs (10, 20, 30 and 40). My maintenance VLAN is VLAN 10, on the 10.0.10.1/24 subnet, defined in my pSense with DHCP active.
Do I have to change the IP of the switch to 10.0.10.2, for example, and setup the switch to access it via VLAN 10? If I do so, can I still access the switch plugging a cable in one port and browsing to the new IP? If someone has it configured in a similar way, could you share the details of the “System” tab?
I am very disconcerted by the fact that a VLAN 1 has been defined in the switch in some of the official guides in Mikrotik’s wiki. Could somebody explain me the role of this VLAN?
Thank you very much for your help.
