several interface problems on 5.0rc8 + intel Core i5+H67
I sent it, I will glad to see fixed 5.0rc9 or special build 5.0rc5 (x86) with ssh problem fixed =)
IRQ balancer, RPS
What do you mean? Balancer works? Or what? And RPS?
these are 2 features that greatly increases throughput of multi-core hardware.
http://wiki.mikrotik.com/wiki/Manual:System/Resource#IRQ_Load_Balancing
Oh… Thanks. But as I said before - multicore - is not possible on rc8 and Core i5+H67. Maybe Mikrotik developers help me…
After installing 5.0rc9 - nothing changed… Very bad…
did you tryed to install latest bios for motherboard?
Intel Core i5 CPU 660 @ 3.33GHz
this is my x86 test router cpu. So what problems exactly you are having with router sporting this CPU?
@janisk, what is model of your motherboard ?
ну например 100 правил в mangle цепочке и 10 в nat и 1000 в роутинге + 300 мегабит трафика - и тебе обеспечена загрузка процессора 50% (если двухядерный проц), так как в версия до 5.х многопроцесорность не работает.
Is there MikroTik 5.0 final supporting Intel 82579V LAN and Intel P67 Chipset?
Multicore is working for now… but i have no load tests on this chipset. On board Ethernet is not supported.
