I am a ubiquiti man, testing Mikrotik, I can only seem to get certain frequencies to work and such as 5500, 5520, 5540, 5560 and up to 5700 with 20MHz spacing and I want 5840 as that is the only frequency I have left that is free.
How can I get this frequency to work.
I have no problem with Ubiquiti and this frequency.
it might be possible that once you configured UK as country 5.8 is not configurable due to the fact that it is a restricted frequency in UK. I know that there is a special “country” called “germany 5.8 fixed p-p” as these channels are limited for p-p links of ISPs ( even not allowed to use it as an p-p in an private/company network ). maybe mikrotik can add similar a option for UK as well. you can configure superchannel for testing purposes. http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#General_interface_properties. but be careful! as you can configure any frequency and any tx power you could do something that’s not allowed in the UK.
Yes, if you personally have a license, it means that UK in general has 5.8 restricted. In this case, change wireless mode to “superchannel” and your frequencies will be unlocked. This mode is for people who have licenses outside their country default regulations.
Again … 40mhz channels are not for Europe … If you really want to use different frequencies and channels i think its better you choose another country that supports your needs, maybe US.
40mhz “Channel Width” field is available only if you have non-N chispet card, for example, R52 (AR5414 chipset).
For N chipset cards like R52N you need to use “HT Extension Channel” option.
