SFP port on wAP ax
Dear MikroTik Team,
I have a suggestion regarding your hardware products.
I own several wAP ax access points, and I have to say they are great. I live in the countryside, in a large house with several additional buildings around it, including barns, garages, and other outbuildings.
So far, the wAP ax units have been working great, even in very dusty environments. A few of them are installed outdoors, but protected under a balcony and mounted on the ceiling. I have been very happy with their performance.
Because of the risk of lightning strikes, I use fiber-optic cables for connections between the buildings. Copper Ethernet cables can be quite risky in this environment, as lightning-induced surges can damage connected equipment.
In fact, whenever there is a serious storm, we sometimes have to turn off the power to protect our electronics. We have several UPS units keeping a few lights and selected access points running, while everything else is disconnected from the electrical grid.
Fiber is therefore the ideal solution for connecting everything safely. However, there is one inconvenience: to use your wAP ax access points with fiber connections, I need to install a separate media converter for each device.
This brings me to my suggestion: Would you consider making a wAP ax version with an integrated SFP or SFP+ port?
I believe this would be a very useful product, especially for people in situations like mine, living in rural areas, on farms, or on properties with multiple buildings. It would eliminate the need for separate media converters, reduce the number of devices and power supplies, simplify installation, and provide a much cleaner and more reliable setup.
Thank you for making great products, and I hope you will consider this suggestion!
Best regards
Good luck with that request... We are still waiting for a lot of APs that Mikrotik promised, switches and routers as well...
Maybe FTC21-ups will be better solution.
How do you power your APs? The best way would be a POE switch with SFP uplink. Even a small RB260GSP can do this.
Yeah, i know... at least i am giving them suggestion about possible solutions for problems that i have
At that point, it wasn't an option, but now it would certainly be one of the possibilities, especially since it provides some UPS functionality for short power outages. However, given that longer outages are also a concern in my case, I suspect I would still need an inline UPS to provide sufficient backup power. Considering that it costs around €100, my current setup, using the media converter and the basic PoE injector that came in the box, is still significantly cheaper option
So far, I have the media converter and PoE injector that came in the box. In my case, it's a 1:1 setup, so I haven't needed a switch. However, thanks for pointing that out. I'll definitely keep it in mind if the need arises in the future.
The thing is, I need a reliable power source at the AP location, but I can't use PoE due to distance limitations and potential storm-related issues. Ideally, the AP would have a 12–57 V DC input, PoE support for those who need it, and an SFP port. That way, I could simply connect the fiber-optic cable to the SFP port and run a DC cable directly from a battery (eg 24V or 36V or 48V) to power the AP. This would be a much cleaner and simpler solution, without the need for additional converters or PoE injectors.
doesn't netmetal ax have a sfp port? why not use that?
https://mikrotik.com/product/netmetal_ax#product_specification
Indeed. But the list price is $169 vs. $89 for wAP ax.
It seems that many (not saying that @ckiki is in the same category) people with ideas about enhanced products assume that the enhanced product will somehow come at same (low) list price.
And you still have no antennas.
Placing a couple el-cheapo HGO-antenna-OUT as Mikrotik suggests for short range is a possibility, 18 US$, but that will have a WAF rating of around -147.
To get into a positive range you will need a panel antenna and paint the netmetal in white, consider some additional 100 US$/unit.
Today, it would be one option worth considering, but it seems a bit overkill for my use case. Also, if I wanted to achieve 100% coverage, I would probably need an additional 2–3 APs for every existing AP, which would make it too expensive.
Another thing I don't quite understand is why there are no ceiling-mounted APs designed for outdoor use. I could imagine simply mounting one underneath the roof, facing downwards. Alternatively, wall-mounted APs with built-in omnidirectional antennas would also make sense.
You can install GESP (https://mikrotik.com/product/rbgesp) to protect your devices. With that no need to turn them off in storm.
I do have some of them, but they don't guarantee that the devices won't get damaged. We also have a number of other electronic appliances, such as TVs, washing machines, etc. When we're away and a storm hits, no one is there to switch off the main power supply. As a result, we sometimes come home to find that some of our devices have been damaged or are completely dead. We are on rock hill side, on very specific side where it is very hard to defend yourself from thunder damages, unless we turn off everything.
Check out the GPEN21 https://mikrotik.com/product/gpen21
